Fuel Additive ?
Fuel Additive ?
I'm thinking of getting some Cetane Boost additive. My buddy says he uses the Cetane Boost w/Anti Gel and it helps in the winter and has improved his mileage.
Any thoughts on using +Cetane Boost® or other brands ?
I live in Interior Alaska, so the anti-gel would be a good additive for those -50f below days.
Ford sells one and if you use theirs at least they cant blame that for problems
PM-23-A] Motorcraft Diesel Anti Gel and Performance Improver-NEW LOW SULFER(PM23A)
I have been using the Motorcraft pm 22 for 4 years now which is 60,000 miles between my 6.0 and 6.4 and knock on wood, no engine mechanical problems. I don't use any anti-gel in the winter, the fuel I buy is winterized fuel. I have a pint glass bottle of fuel that was from Dec. 2010 and on the coldest mornings in my area 4 above I never seen any clouding.
Was worried about that as well and had a heater added to it as part of the winterization I had done to the rig.
I heard about the freeze problem and though I'd beat the freeze to the punch. However, with that said, I found one of my heat pad cords dragging the pavement today and plan to check all of them. It was installed by the dealer
So I just bought a gallon of PM-22A from my local dealer, I got it for a great deal for $44 after tax. My question is, how do you guys get it into the tank? :/ I wasted gotta be atleast an ounce trying to get it in the tank. I am thinking about trying to get a turkey baster. Any suggestions?
Buy yourself a 20 oz. plastic bottle of pm-22a at a Ford dealer. This container has a long neck which makes it spill proof when adding it, I kept it in my rear door bin and when it was getting low I refilled it from my gallon can.
I use a small Gatorade bottle that I have marked a line where it would be filled for a complete fill up of diesel. Then when I top my tank off if I fill the tank half way I simply pour in half of the amount from my bottle. Quarter tank fill, quarter of the bottle and so on.
The Gatorade bottle is a nice size as it does not require a lot of space to store, plus it has a large mouth top so it pours quick and without the need to use a funnel.
