I dont have any personal experience with them, but they seem to be on the lower end of the header scale. If you give this some time, some of the regulars of the list will probably jump on this thread and give their ideas. Are there any headers you had in mind, or just getting a feel for what everyone has?
Just put ford motorsport headers on my 1990. They are supposed to be stainless steel so they should last. They fit great and went on with no problem except for the last bolt on the passenger side. It fit right, just very hard to get a wrench onto. I imagine all headers having the same problem. They also bolted right up to the stock y pipe. Noticed a little extra performance, mostly above 2500 rpm. Cost $309 at summit. FYI get a good quality ratcheting 3/8" 12 point wrench which should make life much easier if you go with these.
I used to have hedman header on my 1969 Mach 1, it has a 351w, I switch to a tremec tko and had to ditch those headers for shorties, I put on JBA's and they made more power and had better fit and quality. Remember you get what you pay for.
Gavin
I currently have some summit shorties. Have had an exhaust leak since day one. Just ordered a set of JBA shorties and in the box they look a lot beefier and a lot higher quality than the summit racing ones. Hopefully get them installed this weekend and eliminate that leak.
2 ways to do it,
right,
and
twice.
don't make my mistake and have to do it twice. Buy a good set, it will save you money in the long run.
89 bronc 351, .020 over, keith black hyper-u pistons, 9:1 comp, MAF, and some other goodies to come.
65 mustang, soon to be 5.0L H.O. FI
I have been using Flowtech shortys with premium gaskets for about two years without leaks or problems. Note : I do retighten my headers at every tune up.
Reviving an old post here...it seems that a lot of y'all are using shortie headers...why is that? I thought that full length headers were supposed to be better. or is all that matters is that they are equal length?
Just asking because I am seriously thinking about replacing my manifolds...then i would go ahead and get a y-pipe and high flow cat and muffler too.
These Bassani headers that y'all keep talikng about look good but what are the sizes that they have like pipes and collector Diameters.
Some say that there is more power to be made with the long tube headers. The biggest advantage the shorties have is there ease of installation and will usually match up to the factory y-pipe. Long tubes can be a bitch to install and route the exhaust out especially in a 4X4 Ford where the transfer case is an obstacle. The Bassani Street Thunder system on my truck is 1 1/2 primaries exiting to a 3" exhaust. If your into serious mods and HP then 1 5/8 primaries would probably be in order (I'm assuming 5.0L here). You'd have to call Bassani to see what primaries are available for your app.
