Strange Dana 41 Rear End
Old 09-09-2011, 08:42 PM
ct50f1's Avatar
ct50f1
ct50f1 is offline
My '50 F-1 came with a Dana 41 rear axle with a ratio tag that reads W 51/13 which works out to 3.92.
According to the shop manual for 49-50-51 the ratios available were 47/11=4.27 or 47/12=3.92. Has anyone seen a setup like this before or have any idea about what type of vehicle the rear end might have come out of?
Old 09-09-2011, 09:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Very unusual... Be interested to see how this turns out! Any signs the perches were re-welded in their present position? I'm also curious about that "W"; my tag doesn't have anything but the numbers.
PS -- have you counted teeth?
Old 09-09-2011, 10:08 PM
youngfordkid's Avatar
youngfordkid
youngfordkid is offline
ive got the same thing! i dont have a tag on mine but i counted the gears and got the same ratio of 3.92 with the same count on the gears. mine is a 49 though.
Old 09-09-2011, 10:46 PM
Doc's Avatar
Doc
Doc is offline
Very interesting. I own 4 dana 41's (only 2 are attached to a truck). All 4 have the following: "W 41/11" (3.73). One is a 49. One is a 50. Other 2 are unknown year. I wil say this, mtflat pointed out that the shop manual had a misprint and should have said 3.73. But that doesn't explain this particular rear end.
Old 09-09-2011, 11:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The truck in your avatar is a '51/'52, it should have as stock a 47/12 = 3.92. Why do you say it's a '49? Was the axle swapped?
Re: the OP; Maybe this explains some of the difference (but not why a '50 would have 3.92's). To get a 3.92 in a D-41 they may have had to use a different gearset than in a D-44
I guess this is the answer; from 48 - 50 you could get any of THREE ratios
Old 09-10-2011, 07:47 AM
HILLBILLY BOB's Avatar
HILLBILLY BOB
HILLBILLY BOB is offline
My 51 came with a 3:73
Old 09-10-2011, 08:27 AM
ct50f1's Avatar
ct50f1
ct50f1 is offline
I don't see any indication that the perches were re-welded or anything else that suggests that this wasn't the stock rear end when the truck was built. According to the firewall numbers, the build date is August, 1950 so I thought it might have something to do with the changeover to the 1951 models (it has the later flat panel bed) but the manual shows the same ratios available for 1951.
I haven't counted the teeth but I took it to Chuck Mantiglia to get the bearings and seals replaced and he agreed that it appears to be 51/13. He also commented that the ring gear was thinner than usual.
Old 09-10-2011, 09:40 AM
mtflat's Avatar
mtflat
mtflat is online now
Ross, or Albuq F1 is the guy that put me onto the shop manual 'misprint' - maybe it wasn't a misprint after all. It might just reflect the fact that later trucks used a different ratio than early F1s since it was printed after '52.
Old 09-10-2011, 03:26 PM
ct50f1's Avatar
ct50f1
ct50f1 is offline
Ross,
What is the source of the chart below the photo in your posting that shows the 3 ratios?
Old 09-10-2011, 04:20 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
The 3.92 ratio was a Dana 41 ratio used in Studibakers of that time frame - Maybe someone swapped a Stude and add the tag
(I just thought that I should add to the confusion)
Old 09-10-2011, 04:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by ct50f1
Ross,
The 48-56 Parts Manual. All three ratios were available from 48-50
Old 09-10-2011, 08:18 PM
CHUCK48-50's Avatar
CHUCK48-50
CHUCK48-50 is online now
I just did a little research. In the 1948-50 Chassis Parts Catalogue, dated July 1950, there are all three ratios listed. The 0M-4209 (a 1950 Mercury car part #) is listed as 3.92 ratio, and only fits 1950. There is no mention of the 1M-4209-A or -B (1951 Mercury car #'s), which would be for the 44.
In the 1948-51 Chassis Parts Catalogue, dated January 1951, all of the numbers show up, and the 1M #'s are listed for 1950-51.
So, apparently the 3.92 ratio got installed in some trucks with model 41's before the switch to the 44! It's interesting to note that no 1950 part numbers were ever assigned to the parts for the 44 rear, even though many of them were installed in 1950 trucks.
Chuck
Old 09-10-2011, 08:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As thin as that ring gear is in the picture, I'd bet it was weak and a transitional effort. Note the differences in tooth counts for the 48-50 3.92 and the 51-52 3.92 -- 51/13 vs 47/11. It's strange they would use the bigger pinion and such a thin ring gear. They must have been "stuck" with using a carrier that was for much smaller pinions (higher ratios) but were scabbing the R&P from the car lineup?
Old 09-11-2011, 07:47 AM
38 coupe's Avatar
38 coupe
38 coupe is offline
Does all this mean that Dana 44 gear sets will bolt into Dana 41 axles?
Old 09-11-2011, 08:48 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That question is always on my mind! I looked up the carrier bearings in the parts catalog; the 48-50 (D-41) and 51-52 (D-44) use the same piece (and it's a real common wheel bearing). That's just one thing that has to be checked but the most obvious.
I don't know enough about these to answer this question; all the carriers on eBay say they are for specific spline-counts. How many splines are our axles? 19 comes to mind, can someone confirm? And what difference does it make as far as the carrier? Can we just put our spider gears in a carrier for lower ratios?
DANA 44 19 SP AXLE OPEN NON POSI CARRIER CASE NEW 3.73 | eBay
Quick Reply: Strange Dana 41 Rear End
