Bronco II Ford Bronco II
89 bronco II question from a newb.
Old 08-27-2011, 07:00 PM
mbxmitch's Avatar
mbxmitch
mbxmitch is offline
first thnks to any one who replies I am just looking for some advice.
In searching for a truck I run across an 89 bronco two its blue and white good body 4x4 automatic unknown millage either 116,000 or 216,000
I can pick it up for 700 dollars or less but he says the engine makes a lot of noise and something about oil clogging up in four holes under the heads or something.
Sounds to me it needs a motor so my questions are.
Is 700 a good price?
is a 502 v8 swap an easy challenge or is a lot of customizing involved?
Old 08-31-2011, 08:51 AM
DFWBII's Avatar
DFWBII
DFWBII is offline
Hi,, I'd go fer it man even if motor is trashed,,you can get another from j/y or here in the Classifieds' section, theres plenty to chose from. get your tools ready for a swap. take off valve covers and clean out the drain holes(probly stopped up with sludge), drain oil, flush engine with kerosene(won't hurt it as it has oil in it) put in new oil & filter, change spark plugs, wires etc. check compression. as for engine swap,,plan on re-wiring, adapting to bell housing, etc. go for next size bigger engine. good luck
Old 08-31-2011, 12:48 PM
smalltrucker's Avatar
smalltrucker
smalltrucker is offline
Stay stock or even the 302 is not really that hard to do. My old room mate just finished his '89' a couple of years ago and just loves it. Had to swap parts from the C-5 trany to a C-4 to retain the stock xfer case. Kept it a mild built so he was able retain the stock axles. Have fun with it, I'd sure jump on the chance to get another BII for that price.
Dave
Old 08-31-2011, 03:40 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Welcome to FTE...be sure to check out your local chapters.....
tahoediesel
Bronco II
09-13-2008 06:04 PM
Allbie16
1978 - 1996 Big Bronco
01-15-2006 09:53 PM
Bronco Beaver
17
12-03-2003 09:33 AM
jared1970
09-23-2003 02:51 PM
jared1970
09-23-2003 12:55 AM
Quick Reply: 89 bronco II question from a newb.
