E4OD no reverse??
Old Aug 4, 2011 | 02:02 PM
farmerbobby's Avatar
farmerbobby
E4OD no reverse??
Hey all, I have a 1990 f250 7.3 IDI with a banks turbo and an E4OD. the truck has been running and driving perfectly ever since i got it three weeks ago. well, i installed a new IP and new injectors on it yesterday. i was on my way to the store this morning and everything was going great. then, when i got on my driveway, i noticed a tree had fallen across. the driveway is VERY steep so i just parked the truck, set the ebrake, and went and cut up the tree. well i hopped back in the truck and cranked it up and let the trans temp get up to normal again before i took off. the whole way up the driveway i could hear the tranny slipping. i pulled off at my neighbors house which is on a flat piece of land thinking that the fluid just got pushed to the back of the tranny. i got the truck all the way up the rest of the driveway and shut it off in the carport. i mowed the lawn and did a couple other things then went to hop in the truck and leave. while the truck was still in park, i can mash the gas and it tries to push itself forward but it will not actually go anywhere. it acts like it is in gear but with the ebrake on. it does the same in reverse. it doesnt try to go backwards, only forwards. it doesnt even have neutral. neutral is like the truck is in overdrive. i can drive the truck forwards just fine in either neutral, OD, 2, or 1. but it WILL NOT budge in reverse. fluid level is fine, pressures good, idk what else to check. any suggestions? sorry for the long post just trying to be accurate
Old Aug 4, 2011 | 02:08 PM
Aune163rd's Avatar
Aune163rd
Is the Ebrake still on? Sorry but we have had soem guys ask that question as to why the truck wont move very well...and turns out their E-brake is on or something along those lines.
Old Aug 4, 2011 | 02:11 PM
farmerbobby
haha no im not that dumb. the thing that gets me is why does it try to move forward in park or reverse? i dont get it.
Old Aug 4, 2011 | 02:12 PM
Aune163rd's Avatar
Aune163rd
Now that we are off the common sense DOH moments . Onto more serious matters, its a possiblity with The condition you described it might be a hard part failure, clutch failure, leak on the reverse hydralic circuit or any combination of the above.
EDIT: Pull your engine & transmission trouble codes, and post those codes here, I am not a E4OD guru, but F250HDXLT is, and he will help you to his whits end.
Old Aug 4, 2011 | 02:16 PM
farmerbobby
at the moment, my code reader is at my buddies about 25 miles away. and im stuck here at the house with my broke truck
Old Aug 4, 2011 | 02:17 PM
Aune163rd's Avatar
Aune163rd
Well drive your lawnmower (I have done it or I wouldnt have said it, hopped on, had a cooler in my little pull around trailer, and drove 8 miles to my buddies house, then parts store)
Old Aug 4, 2011 | 02:22 PM
farmerbobby
haha 50 miles is a long ways to go on a lawnmower
Old Aug 4, 2011 | 02:27 PM
Aune163rd's Avatar
Aune163rd
hey man...just grab a 24 case, no cop will pull you over, they laugh to hard to do so...it works....
Old Aug 4, 2011 | 02:29 PM
farmerbobby
well the only way to get down there is on the interstate soooo........ yeah lol
Old Aug 4, 2011 | 02:38 PM
snaponprofile's Avatar
snaponprofile
Are any plugs loose on the transmission, any wires melted or not plugged in?
How about the side of you IP? It the sensor there tight? Is the o/d light blinking?
Old Aug 4, 2011 | 02:40 PM
Lazy K's Avatar
Lazy K
Not an expert but what color is the trans fluid? Does it smell burnt?
Sounds like the forward clutch pack has welded itself together.
Old Aug 4, 2011 | 02:47 PM
farmerbobby
all plugs tight and in good shape on the trans and the IP. Trans fluid is still good and healthy red. when i put it in neutral, the truck will roll back on the hill, but if i give it gas, it starts driving forward.
Old Aug 4, 2011 | 02:55 PM
Lazy K's Avatar
Lazy K
Still sounds like the forward clutch pack.
Hopefully other opinions will follow.
Old Aug 4, 2011 | 03:01 PM
farmerbobby
i hope not because my house is on top of a huge hill and there isnt any way to get a rollback or anything up here to take it up to the transmission place. if it was anything wrong with the sensors or something i could do it but ive never really worked on a tranny before. at least not automatics. i can rebuild a t5 out of a mustang but im lost when it comes to this thing.
Old Aug 4, 2011 | 03:03 PM
farmerbobby
and the OD light is not blinking at all. i can switch it into and out of OD just fine
