Runs progressively worse as I drive
Old 08-17-2011, 03:35 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Originally Posted by phurst
Drove to work today like a champ.
Shaun, I hope you find that it's a simple wiring issue.
That's good. Let's hope it stays this way.
And thanks!
  #62
Old 07-25-2012, 11:42 AM
c2z4s9's Avatar
c2z4s9
c2z4s9 is offline
Well, the universe is a funny thing I suppose. Yesterday, my daily driver decided it was fed up with it's mundane existence, and decided to drop a valve seat into number four cylinder.
I know this is an old thread but... your daily driver, was it an escort?
  #63
Old 07-25-2012, 12:14 PM
phurst's Avatar
phurst
phurst is offline
Almost, it was a Focus.
  #64
Old 07-25-2012, 12:17 PM
c2z4s9's Avatar
c2z4s9
c2z4s9 is offline
yeah, i've heard of that happening. Almost happened to my escort too, but i caught it and changed the head out ... if you believe that. It's been going strong since has over 250k on it.
  #65
Old 07-25-2012, 12:26 PM
c2z4s9's Avatar
c2z4s9
c2z4s9 is offline
Did you ever discover what the problem with your truck was or did the problem simply never return? I'm experiencing something pretty similar.
  #66
Old 07-25-2012, 12:32 PM
phurst's Avatar
phurst
phurst is offline
Yep, it was a leaky brake booster diaphragm.
  #67
Old 07-25-2012, 12:34 PM
c2z4s9's Avatar
c2z4s9
c2z4s9 is offline
@(&## I know my brake booster is leaking -- looks like fluid has run out over time and peeled the paint away and i thought I've heard a little sucking noise when in the cab. So this problem amounts to a vacuum leak then? How hard was it to change the thing? You did have to replace it right?
  #68
Old 07-25-2012, 12:41 PM
phurst's Avatar
phurst
phurst is offline
If you can hear sucking, it's a substantial leak. It is indeed a vacuum leak. I bought the booster and MC together since mine, like yours was leaking fluid. It's an easy swap, did mine in the rain in about an hour, including bleeding the MC.
  #69
Old 07-25-2012, 12:44 PM
c2z4s9's Avatar
c2z4s9
c2z4s9 is offline
oh wow ok, then I'll give it a try thanks for the info.
  #70
Old 07-25-2012, 02:52 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
If you see signs of a brake fluid leak on the booster you should have also smelt brake fluid being burnt in your exhaust as it is being sucked into the intake systm while the engine is running.
  #71
Old 07-25-2012, 03:17 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Originally Posted by Moto Mel
If you see signs of a brake fluid leak on the booster you should have also smelt brake fluid...
Hey, Moto, are you British by chance?
  #72
Old 07-25-2012, 03:42 PM
c2z4s9's Avatar
c2z4s9
c2z4s9 is offline
I can't say that I've noticed the burned smell. The fluid leak must be very slight, I can't say I've noticed a change in the level.
  #73
Old 07-25-2012, 05:23 PM
1983F1503004x4's Avatar
1983F1503004x4
1983F1503004x4 is offline
I've noticed that since my diaphragm in the booster has started leaking, the hose has had a bit of brake fluid in it.
Part of my reason for disconnecting it and plugging the ports until it gets a new booster and master.
  #74
Old 07-25-2012, 06:44 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
No I'm from the good old U.S. of A.
Born in Kalamazoo, the home of Checker Motors.
Why do you ask?
  #75
Old 07-25-2012, 08:43 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Why do you ask?
I think smelt is British English, as opposed to smelled.
Quick Reply: Runs progressively worse as I drive
