EBC Yellowstuff pads - 1000mi report
#31
Well i had the EBC "green's" on a ls1 powered T/A a few years back, but didnt really do much driving on the stocks before. Never had any fade, even while at an autocross event. Gonna spend the money through riffraf and get me some Greenstuff now since its taking me a mile to stop this damn truck from 25 mph's up hill!
#32
I rebuild my breaks last November and drove about 4kmls since than.
I purchased 4 EBC Dimpled and Slotted Discs and combined them with the
yellow stuff Pads all around....and to top it off I bought a complete set of
Stainless Steel Braided Teflon Lines for the Front and Back.
After a complete brakefluid flush and upgrade to DOT4 fluid I thought really
that I bite the steeringwheel at the first step on the pedal.
Maaaan.....what a difference!
So.....after those mls I can recommened this combination. The dust is average, the pads hold up great and even the dimpled rotors shows only a minimal wear.
.....and I drive sometimes a bit agressive and fast here in Germany.
......all I say is the word AUTOBAHN.
Friends of me drive the mighty Explorer and drive there a similar setup, inspite of the yellow stuff. They swear to the red stuff, because they say, that the red stuff bites as hard as the yellow stuff but even if the breaks are cool. The yellows bite even more if they are hot, where the red stuff bite la bit less in comparison to the yellow pads, because they love high temperatures.
What do you need is the question? Do you like driving agressive and fast or you do a lot of towing in a mountain scenery...than you should get those yellow pads.
Otherwise you would be probably better with buying the red stuff.
Anyway....those EBCs are a very good choice. Pads and Rotors.
Just my 2cents......
BtW.....if youre asking Brent......you dont need breaks at all....stretching your legs like Fred in the Flintstone Mobil is way enough
#33
I think I'm the only one here that has not been impressed with these. I had green pads in for awhile but they were a bit to noisy for my taste ( I don't want to hear anything!) I went back to Ford brown box pads, think the biggest difference I found were going with new brake lines as far as stopping power. But again I'm definitely the minority here. Just my humble .02
#34
#35
Have had the EBC Slotted and Dimpled Hubs on my two wheel drive for two years having turned them once. I use my EX for work and occasionally pull a 12 ft trailer for catering. Have used Yellowstuff for both exchanges and have replaced the calipers once replacing the slide pin kit both times. I have close to 60K miles on the rotors. It was very pricey and I shopped like mad to get the price on hubs and pads rock bottom. I was changing autozone duralast golds every 3 to 5 months like clock work with the warp wobble every time. I felt foolish turning the EBC's but just didn't have the cash for new front hubs. I have almost run the life out of a second set of pads and the turned hubs have yet to give the warp wobble. I did follow the break in instructions and picked up the EBC DVD and did all their recommended install checks. For my money and Time I will go with EBC's again having amazing return on performance. I have looked at other options but there really are not good ones for the two wheel drive EX. The only con is they make dust. You do have to clean the wheels regularly, however, that is better than seeing the autozone guy once a quarter.
As far as the stopping power and peddle ford should have spec'd something similar to this set up at purchase. Its everything you hoped to have. Smooth, rapid, controlled stopping with full cargo and trailer/boat. Plus longevity.
Someone would really have to have a fantastic setup that cost about the same as an autozone set of brakes to make me change from the EBC Sport hubs with Yellowstuff. For what its worth the EBC rep did not feel the Greenstuff would perform with towing and was not recommended by the EBC engineers for a truck as heavy as the EX.
For what its worth.
For what its worth.
#36
I'll be towing a 4wd F250 CCSB on a 2-car GN trailer from GA to NJ this weekend and the mountains will put these 'old' pads to the test again.
#39
#40
I recently put EBC Green Stuff on the front of my truck and they are awesome! I had HAWK LTS pads but they squeaked and I didn't care for the cold stopping out of the driveway feel. I don't tow that heavy and don't brake aggressively. I plan to tow a car trailer next month about 1000 miles so I'll be curious to see how they perform, I suspect well. They are more dusty than other pads I've tried but they stop the best, by far.
#44
The EBC Greenstuff are probably slightly less dust than OEM pads. The Yellowstuff are comparable to OEM. The dust is easily washed off with a sponge and clean water if you do it regularly. The amount of dust depends on the type of braking you do. Hard/aggressive braking will produce more dust. I ran these pads with polished aluminum wheels and never complained about dust.
If you do moderate towing and don't brake aggressively, expect long life out of even the Yellowstuff pads. I have used both Yellow and Green - and I see no reason not to just run the Yellow pads. STOPPING is very, very important to me!!! I like the confidence I get running with good brakes!
#45
I am with Michael (LivinLarge) from earlier, I was very unimpressed with the EBCs I had, I had the green stuffs on for about 5k miles and hated them. I felt no noticeable stopping improvement and the dust was HORRIBLE. Biggest braking difference I have noticed is with new brake lines. I could live with the insane amount of dust if there were a real seat of the pants improvement....it just wasn't there for me, so I guess I'm with Michael in the minority!
