want to rebuild my 94 f150 302 motor
rebuild a 302
I'm sorry guyz, yes i have rebuilt a motor an pulled a motor. it was a Honda motor, just never a v8. my ? is once the block is done do i have to use over sized piston if i get the cylinder honed i was told i do but never did that with a Honda unless i was goin bigger but in this case im not just want standard hone.
That depends on the math...
bring the pistons with you when you take the block in, they will measure.and answer your question. Most likely if your motor is high mileage, you will need to go oversize pistons
20
04-02-2009 05:58 PM
dfisher1
11-23-2004 10:20 AM
