Fluid Changes
Old Jul 18, 2011 | 06:18 PM
09' Lariat's Avatar
09' Lariat
Fluid Changes
Hi everyone, I have a 2009 F150 5.4 that is 4x4 and I would like to get some advice on performing fluid changes. The truck is coming up on 30,000 miles and I do tow a lot. The transmission and front differential seem to be the hardest fluids to change. Has anyone performed this service yet?
Old Jul 19, 2011 | 06:20 AM
shotgunz's Avatar
shotgunz
1. Why are you changing the transmission and front differential so early?
2. If you intend on doing your own maintenace
a. Look into a shop service manual
b. To protect your drivetrain (and possibly ESP [if you purchased it] FULLY document (receipts, digital photos, etc.) all driveway maintenance
Old Jul 19, 2011 | 06:22 AM
ford390gashog's Avatar
ford390gashog
The front diff is easier to extract the fluid rather than removing the cover. I also think unless it has been in deep water the front diff fluid is fine and does not need to be changed. The tranny is not that bad either, I just do a partial fluid change every 20-30k. Just drop the pan clean the magnet and reinstall with the original gasket and fill with about 5 quarts of fluid.
Old Jul 20, 2011 | 06:20 AM
stormsearch's Avatar
stormsearch
That is what I will likely do around 60 - 75K. Just wish there was still a drain bolt for tc.
