Donor van ?
I do believe the door parts etc are much the same from '92 forward. Obviously when the front end sheet metal changed with the new grille and hood those might not transfer very well.
I'm in the auto glass business and know for a fact the windows are all the same size which means they'll interchange from at least '92 through '08.
If you're looking for a donor van carefully check inside any door you'll purchase---rust hides inside only to emerge after its been disturbed by refinishing etc. Its a bit more work before hand but yields a sound re-fitted van once you're done.
HTH
HTH
"92+ doors" themselves should swap. However few of the parts attached to the doors "are the same". Exterior mirrors changed, interior panels changed, and I believe the wire harness/connectors changed w/electrical components in doors.
While windows stayed the same size, there have been several different colors & reflective coatings that complicate matching glass.
pweng1
06-11-2014 10:45 AM
BriWas
05-08-2013 08:22 AM
octaneforce
06-19-2009 11:18 PM
