Cab Interchange
Old Jul 14, 2011 | 08:34 PM
Truck problems2's Avatar
Truck problems2
Cab Interchange
Can you put a 78 cab on a 74 narrow frame truck?
Old Jul 14, 2011 | 08:50 PM
Tsoptich's Avatar
Tsoptich
I am putting a 78 f250 2wd cab and body on a 74 f100 4x4 frame. All the holes match up.
Old Jul 14, 2011 | 10:35 PM
highboy1975's Avatar
highboy1975
what is a narrow frame truck? whats the model? f350?
Old Jul 14, 2011 | 10:43 PM
650's Avatar
650
I assume you mean highboy and the answer is yes. The front mounts will be the same. The back 2 though will need to be re-drilled though since the highboys mounts are on the outside instead of on the inside. At least this is how it worked out for my truck when we did the swap. My swap was a 78 F.150 2wd cab onto a 1976 highboy.
Old Jul 15, 2011 | 12:01 AM
RunninD's Avatar
RunninD
Unless you are putting the cab on a hiboy the frame mounts are identical. The only variation I have found in the 73-79 standard cabs in the Hiboy. In that style (F250 4X4's) the rear mounts are wider. otherwise the cabs all mount to the frame without any issues
berlincam86
74
Mar 17, 2019 09:26 AM
berlincam86
'80-'86 FAQs (Frequently Asked Questions)
59
Sep 30, 2016 12:20 PM
speakerfritz
May 8, 2016 04:45 PM
Eaglescout94
Jul 9, 2015 08:51 AM
johnfin1
Nov 2, 2014 11:39 AM
