Rebuilding a Double Cardan Joint (Vid/Pics)
Old 02-27-2012, 04:26 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Sure. You can drive it without a front drive shaft.
Without the front drive shaft you can go anywhere a 2WD can go.
You shouldn't drive around in 2WD with the hubs locked unless it is really necessary.
Old 02-27-2012, 04:29 PM
chalupien's Avatar
chalupien
chalupien is offline
Nice thats what ive been doing anyway...
Old 02-27-2012, 05:13 PM
PaysonPSD's Avatar
PaysonPSD
By the way, Welcome to . Stick around. You'll learn a lot. I did.
Old 02-28-2012, 05:27 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Great "how to", Thanks reps sent
Old 03-08-2012, 10:55 AM
fbh31118's Avatar
fbh31118
fbh31118 is offline
I always knew how the joint worked but never knew how to rebuild it. Great write up, answered all the questions that I had! Reps your way! Thanks again.
Old 04-02-2012, 12:00 AM
slim613's Avatar
slim613
slim613 is offline
i been searching for this and trying to get all kinds of help... THANK YOU!!!!
Old 11-18-2012, 02:41 PM
Langpie's Avatar
Langpie
Langpie is offline
Great write up! Mine is torn apart at my dads shop currently, said I need to replace the flange where the centering ball is. Anyone have a part # for that? Also what is the spicer # for the front u-joint? Same as 5-1350X?
Old 11-20-2012, 01:32 PM
Langpie's Avatar
Langpie
Langpie is offline
bump to the top
Old 11-20-2012, 07:39 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
What are the symptoms when this joint begins to fail?
I have a super loud whining gear noise from 25 mph and above but only when on the accelerator. Sometimes it sounds like its emanating from the front other times from underneath the cab. Its starts at 25 mph and reaches a crescendo at 50 or so until other sounds mask it. Its bloody loud.
Ive been hauling some heavy loads lately and its getting worse....i think i even hear it when off the gas now. But its crazy loud when on the throttle.
Mine in a 4wd but this happens in 2wd with hubs unlocked.
Could this joint be the cause? 197k miles.
Old 11-22-2012, 10:56 AM
Langpie's Avatar
Langpie
Langpie is offline
Well that drive shaft does not move in 2wd. Even though hubs are unlocked I'd reach under and try to turn it, should spin freely. Mine needed replaceing bc it had A LOT of play.
Old 11-24-2012, 12:30 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Mr. Langpie, seems like i need a basic lesson in truck morphology! I dont even know where the double cardan joint sits. Im new to trucks, quite frankly.
Youre telling me to try and spin then front drive shaft when front hubs are unlocked just to test if that joint is going bad?, but unrelated to my gear whine issue? Yes?
Old 11-24-2012, 07:32 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
this was your front 4x4 driveshaft?
  #28
Old 03-12-2013, 05:31 AM
DrQuad's Avatar
DrQuad
DrQuad is offline
Great write up and thanks.
FYI - The dust seal that goes over the CV ball/scoket is a Spicer P/N 2-86-418.
  #29
Old 11-24-2013, 03:34 PM
rikosintie's Avatar
rikosintie
rikosintie is offline
My symptom was a rythmic squeaking noise as soon as I would start moving.
I found this write up and pulled the drive shaft out. The centering ball was trashed and I only have 70,000 miles on the truck.
Great write up, it made it easy to do the repair. One note, NAPA U-Joint # 331 is the correct size and has a Zerk fitting. Seemed like the way to go but there isn't enough room on the drive shaft side to clear the Zerk so I had to return it. I bought a Federal/Mogul that didn't have a hole for a Zerk but it included a super short grease fitting that would have cleared. Go figure.
I didn't read the entire thread so I missed the part number for the seal that goes over the ball. NAPA didn't have a part number for it even though they had the ball socket. Mine was in good shape and hopefuly it wasn't a big mistake not replacing it.
Thanks!
Michael
  #30
Old 01-01-2014, 11:21 AM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Fyi you cant find the rubber dust seal that goes around the ball. I went to home depot and found a
1 1/4" fernco fitting in the plumbing isle. Its made of thicker tougher rubber then the original. All you have to do is cut it to the right height. And it snaps right on over that ball kit.
Also you cant find the neapco ball anymore. But i found moog makes it. Its a precision 617 and O reillys sell it. hope this helps others.
Quick Reply: Rebuilding a Double Cardan Joint (Vid/Pics)
