Sponsored by: Real Truck
Alignment help
Old Jul 9, 2011 | 10:23 PM
reddogracing's Avatar
reddogracing
Alignment help
Working on front end and had alignment. Was told prior that truck crabs down the road. Shop said rear axle just out of spec. ..27 right rear. -.27 left rear.
What direction and how far do I need to shift rear axle to get it closer to 0 0
Ie left wheel back. Right wheel forward or vs versa
Old Jul 10, 2011 | 09:01 AM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like the left rear wheel need to go backwards, but please do not only take my word for it.
Overall, 1/4 inch out on the rear axle doesn't sound like a lot. I'm surprised someone said the truck crabs.
Old Jul 10, 2011 | 10:39 AM
reddogracing
Spec range is + .25 degree. To -.25 degree. So I don't know how far that will be in movement
Old Jul 10, 2011 | 12:43 PM
FireMe's Avatar
FireMe
Left wheel back, right wheel forward.
But the time to do that would have been while it was on the rack. With air tools it would have been about a 15 minute job assuming the u-bolts aren't completely rusted. You now have no way of measuring the changes you make, and there is only a small amount of adjustment available.
You will also affect the steering wheel aligment when you adjust the rear, so that will need to be tweaked again.
Old Jul 10, 2011 | 03:03 PM
reddogracing
Yea I wish they would have tried. My normal alignment shop said they couldn't lift my truck. Shop I went to lazy
v10kenj
2009 - 2014 F150
Jan 10, 2014 10:10 AM
jc8825
Jun 4, 2012 06:21 PM
howarda
Sep 25, 2006 10:36 AM
FormerRammer
All Things Towing
Mar 10, 2005 12:52 PM
mrak
Jun 4, 2003 07:37 PM
