Tire sizing reprogramming question
Old Jul 8, 2011 | 03:30 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Ok so calibrating the tire size with AE was a breeze. Only had to try four different sizes before the GPS and Speedo ran true to each other.
Now for the question: I had to set the size of the tires on AE to 32.25" to get the speedo to run in time with the GPS. Accurate to 90 MPH. Now I Have 315 75 R16 wheels and 3.73 gears. I'm pretty sure a 315 would equate to a 34.60" right? Just wondering why that I had to actually program almost three inches smaller to get it to calibrate.
Thoughts?
Old Jul 8, 2011 | 07:11 PM
F350-6's Avatar
F350-6
Because the speedo was off from the factory. If you had corrected to the correct size, then you would have remained off by the same factory settings.
I drove a couple hundred thousand miles on my truck before I got a GPS and discovered my speedo had been off since day one.
Old Jul 8, 2011 | 08:41 PM
F-250 Super Duty
Makes sense to me! When I used to take it to the dealer they told me they calibrated the speedo everytime I went to a larger tire. Guess they lied... I'm really liking AE!
Old Jul 8, 2011 | 10:19 PM
woodnthings's Avatar
woodnthings
I have found that every truck I have recalibrated required smaller than actual size. I always measure the actual height, then start 2" less than measured. I usually get it pretty close or right on that way.
Old Jul 9, 2011 | 07:59 AM
zx250's Avatar
zx250
Of the next Riffraff East
Mine is dead on, set by measuring the actual height of the tire while on the truck and a hard surfuce. Up and down, not across.
Old Jul 9, 2011 | 08:42 AM
jwhitetail's Avatar
jwhitetail
That is about right 315 are only 33.5 inches tall, you can check your AE buy putting a mark of white paint on the rear tire at the bottom dead center,and mark the ground, drive truck till one full revolution, measure distance and divide by 3.146. 315 only measure 33.5 at the most depends on the brand, my 285-16 michelins are programmed at 31.75.
