Synthitic Oil Question
Get the popcorn this should be a long run....
Most all Snys Ols are good. If you run 10k to 15 k and use UOA for trending then you have a choice of (Amsoil, Royal Purple, Shaffer, or Mobile 1) my favorites. In years past Mobile quit running the one year oil change ads due to revenue loss.
Like stock investments your choices may vary depending on your style of vehicle use. BTW oil change for Amsoil should NOT cost $100.... that's what I pay for my PSD oil changes. 6qts and a filter should not run over$55 or so. with the new 7500 mile oil changes Amsoil has a lower cost XL series.
But when it comes to the open question of the "BEST" only you can answer that.
However yo can spend some time at the "bob is the oil guy" web site and get up to speed very quick on all the major oils and then that should help you out. Due to personal experience with the results of my UOA for my PSD, I will use Amsoil 5-20 and run for the year. Then will look at adding a oil by-pass filter like the oil burner.
Hope this helps this can be a touchy subject for many (guilty also long ago) ...
Don't use cheap filters.....you get what you pay for. Save yourself the hassel and cut apart your flavor filter to see for yourself.
Next thing you'll say is to fill up at the discount bottom of the barge gas station, or to eat chocolate sandwhich cookies over real Oreos.
George
I'm guessing that the person who made the post about Motorcraft oil at Walmart was also implying the purchase of Motorcraft filters (not Walmart house brand), which are great filters with some design advantages over many more expensive types. The Motorcraft FL820S is a great filter for Ford engines.
George
George
Walmart is a great place to find MotorCraft parts at a good price.
Thanks.....C-man
PS oil does make a difference. I used to use 15-40 Amsoil in my PSD and then went to 5-40 and it's a new ball game what a difference. So, now I will stick w/ 5-40 but will hold judgment until the UOA results come in. "Bout nuther 3 months or so to see how the RV towing and daily use holds up.
Glad your tune up is giving you such good results.
109,000 on my clock and have used ford 5-20 since day one.. Just towed my 30 ft camper from jersey to Florida and truck temp was about 205 210 most of the trip.... 8.4 mpg's (not happy about that) thinkin of changin to royal purple myself... And for you guys that are only puttin 6qt's in your truck.. mine takes 7+... same motor... also i add marvel mystery oil to it as well..... have changed my oil ever 3k since first oil change.
Mark
Mark
C-man,
I change my plugs around every 60,000 to prevent breaking them off and that is what the manufatures recommend also with aluminum heads. I run the motorcraft platinums that are the new style for just put out for the 5.4l they are about 8 bucks each at checkers auto parts.
I am just debating about every how many miles I should change my oil now running Royal purple. I have heard once a year and also every 60,000 what do you recommend.
Thanks Jake
Thanks Jake
