According to owners manual there is one fuse for cig lighter(number 29) and another for power point.(number 34). Both in panel on drivers side of dash. Did you check both?
I found a blown fuse in the 34 slot. Have power point power now but still no cig lighter, but that is fine, I only need to charge a phone and do not smoke. Thanks again, I did not notice the seperate fuse for the power point until you pointed it out. I gave you a big ole rep point!!
Was hoping if it was a fuse possibly they were interlinked and you would get power back to both. Glad you have at least one is working for now. The other one might be a ground lead like Otahyani mentioned. If you get adventuresome could pull that trim ring around radio and investigate.
