79 f250 super cab 4x4
Old 06-28-2011, 03:39 PM
boggin79ford's Avatar
boggin79ford
boggin79ford is offline
So i picked up this super cab a few months ago and have been working on it little by little. It is a lariat model so it came with all the bells and whistles like tilt column, intermittent wipers, lighted vanity mirror, and so on..I picked it up for $900 and about 5 hours of driving north to get it. it had a rebuilt 400 engine and c6 trans, np205 tcase with a dana 44 front axle and 60 rear.
heres when i first brought it home.
first thing i did was remove the camper
Old 06-28-2011, 03:44 PM
boggin79ford
I then swapped in a front dana 60 with crossover steering and installed a 6" skyjacker lift and 37" tires. also put on my bumper with warn 12k winch.
i cleaned up the engine bay a bit and installed dual optima red tops, new super cooler radiator and a few other things.
Old 06-28-2011, 03:50 PM
boggin79ford
Now im at the point where im swapping in a np435 manual trans. i had the trans rebuilt by a friend and i resealed the transfer case.
since im already going to have the rear drive shaft redone with 1350 yokes im going to swap in a 14 bolt with a detroit locker and disc brakes.
I just started tearing it down today and here is how it sits.
Old 06-28-2011, 04:13 PM
vic_v8's Avatar
vic_v8
vic_v8 is offline
they day you brought it home, was worth $3000 up here all day long.
Old 06-28-2011, 05:00 PM
kbrenner536's Avatar
kbrenner536
kbrenner536 is offline
Same here. This is the kinda find you only hear about and **** and moan cus you wish you found it haha.
Old 06-28-2011, 08:55 PM
PA74F250's Avatar
PA74F250
PA74F250 is offline
What type of crossover setup did you use? I'd like to see some pics if you have some.
Thanks
Old 06-28-2011, 08:59 PM
70 Bronco TX's Avatar
70 Bronco TX
70 Bronco TX is offline
Cursing you...nice truck!
Old 06-28-2011, 10:48 PM
73f250highboy's Avatar
73f250highboy
73f250highboy is offline
Are you rich or something?? haha
Old 06-28-2011, 10:50 PM
boggin79ford
Thanks
i got the steering arm off my buddies chevy dana 60 for free and i ordered the crossover tube and used chevy tie rod ends. i already had the drop pitman arm i just had to rotate it 90 degrees.
Size:  142.8 KB<embed id="ZeroClipboardMovie_4" src="http://pic.pbsrc.com/flash/ZeroClipboardFV2.swf" loop="false" menu="false" quality="best" bgcolor="#ffffff" name="ZeroClipboardMovie_4" allowscriptaccess="always" allowfullscreen="false" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" flashvars="id=4&text=%255BIMG%255Dhttp%253A//i32.photobucket.com/albums/d49/boggin79ford/Big%252520green/DSC00116.jpg%255B/IMG%255D" wmode="transparent" align="middle" height="100%" width="100%">
Old 06-28-2011, 10:53 PM
boggin79ford
haha i wish.... im broke i have been saving parts for a while now..
Old 06-28-2011, 11:10 PM
RednecksF150's Avatar
RednecksF150
RednecksF150 is offline
I wish I could find a deal like that....
Old 06-29-2011, 07:02 AM
ford141's Avatar
ford141
ford141 is offline
Wow, very nice truck and a steal for $900. There is one very similar to that for sale locally for $5000. And he will probably get that for it.
Old 06-29-2011, 08:04 AM
PA74F250's Avatar
PA74F250
PA74F250 is offline
<EMBED id=ZeroClipboardMovie_4 height="100%" name=ZeroClipboardMovie_4 type=application/x-shockwave-flash align=middle pluginspage=http://www.macromedia.com/go/getflashplayer width="100%" src=http://pic.pbsrc.com/flash/ZeroClipboardFV2.swf wmode="transparent" flashvars="id=4&text=%255BIMG%255Dhttp%253A//i32.photobucket.com/albums/d49/boggin79ford/Big%252520green/DSC00116.jpg%255B/IMG%255D" allowfullscreen="false" allowscriptaccess="always" bgcolor="#ffffff" quality="best" menu="false" loop="false">
Thanks. I was hoping you had a bought kit. I like the looks of the crossover and I'm sure it drives better than the push/pull. I'm in the middle of the D60 swap and it looks like I'm going to need a drop pitman arm and another drang link possibly. So I'm trying to decide if I should just go the crossover route.
Old 06-29-2011, 09:15 AM
NBC-Steve's Avatar
NBC-Steve
NBC-Steve is offline
That is a very good looking truck. Where did you find it? I'm about 5 hours North of you. Just curious.
Old 06-29-2011, 09:24 AM
vic_v8's Avatar
vic_v8
vic_v8 is offline
I bought the cross over kit from Sky Manufacturing
Quick Reply: 79 f250 super cab 4x4
