OLD DECODES
#1128
C8TZ-16720-AA Right & C8TZ-16721-AA Left .. Hood Side Emblems / Obsolete
1968 from serial number C70,001 & 1969.
No Ford dealer or obsolete parts vendor has any, none on ebay.
See the link in post #1124 for the early version (1963/67 & 1968 before serial number C70,001).
#1129
I'm new here and plan on buying my first Ford.
Would like to know more about this truck (fire truck).
VIN: C85RU552225 / W.B.: 153 / Color: J / Model: C850 / Body: A91B / Trans: Q / Axle: -- (Domestic Special Order) / Max GVW lbs: 27000 / Cert Net HP: 235 / RPM: 3000 / D.S.O.: 320749
Thank you for what information you can provide.
R = 534 4V V8 (not a Rotary! ).
U = Louisville KY Assembly Plant.
552225 = 1964.
153" Wheelbase.
J = Rangoon Red.
C850 Tilt Cab (gas), 27,000 lbs. GVWR
A91B: A = Silver Gray Crush Vinyl & Gray Twill Stripe Woven Plastic / 91B = Custom Cab.
Q = Dana(Spicer) model 6352 5 Speed Direct.
Front/Rear axles = Domestic Special Order.
27,000 lbs. Gross Vehicle Weight Rating.
235 net HP @ 3,000 RPM
320749:
32 = Cleveland OH Ford District Sales Office, where the original selling dealer ordered the truck from.
0749 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
#1132
NumberDummy
I've had this 93 F-800 for a while and I believe you decoded it some years ago but I can't find that info now.
Would you do it again please.
Mainly I'm trying to figure what rear axle it has and the gear ratio if possible.
It looks like a Rockwell but the tag is missing.
#1134
NumberDummy, I've had this 93 F-800 for a while and I believe you decoded it some years ago but I can't find that info now.
Would you do it again please. Mainly I'm trying to figure what rear axle it has and the gear ratio if possible.
#1135
Thanks!
4.10's work better for me, I was thinking it may have 3.70's
Just looked up the specs on the Allison MD3060 trans it has, .65 OD explains why it will run so fast.
#1137
C60 = C600 Tilt Cab (gas).
D = 330 2V Heavy Duty FT engine.
B44156 = 1967.
135" Wheelbase.
COLOR: Blank.*
C600 Tilt Cab (gas), 20000 lbs. GVWR
A91: A = Light Gray Crush Vinyl & Gray Twill Stripe Woven Plastic / 91 = 91B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
64 = Timken model F106N Single Speed Rear Axle / 6.80-1 / 15,000 lbs. Rear Axle Capacity.
20,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3800 RPM
167245:
16 = Philadelphia PA Ford District Sales Office, where the original selling dealer ordered the truck from.
7245 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
B44156 = 1967.
135" Wheelbase.
COLOR: Blank.*
167245:
#1138
VIN Decoder
B44156 = 1967.
135" Wheelbase.
COLOR: Blank.*
167245:
B44156 = 1967.
135" Wheelbase.
COLOR: Blank.*
167245:
Thank you for your help.
Could I ask you to decode one more VIN?
The GVWR I believe is 23000.
Really do appreciate the help.
Jonathan
#1139
C70 = C700 Tilt Cab (gas).
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
CC9436 = 1978.
175" Wheelbase.
B = Dark Jade Metallic.
C707 = C700 Tilt Cab (gas), 23000 lbs. GVWR
4A8: 4A = Black Heavy Duty Vinyl - Full Width Seat // 8 = 91A Standard Cab.
B2 = Clark model 282V 5 Speed Direct.
E3?:
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity.
? = Unreadable letter for the front axle code.
23,000 lbs. Gross Vehicle Weight Rating.
CC9436 = 1978.
175" Wheelbase.
E3?:
#1140
Hey Number, I’ve been trying to find info on the trans the 65 I’m trading for. I can’t seem to find anything on it. Do u have sources on those? Here is the vin as I don’t have the trans info handy without looking at another post. Also is this a decent driveline combo? Seems different then most I’ve seen on here...
