Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
  #556
Old 12-19-2016, 03:30 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is online now
Received 3,375 Likes on 1,768 Posts
(edited because Bill answered already)
  #557
Old 12-19-2016, 03:31 PM
psmith0803's Avatar
psmith0803
psmith0803 is offline
Well I think I got it ran down thru another source, it's called a :
New OEM Ford Medium Heavy Truck Brake Camshaft Bracket Assembly
New OEM Ford Medium Heavy Truck Brake Camshaft Bracket Assembly | eBay
I don't know if I should proud or ashamed that I stumped you but I'm leaning towards shame because I was using bad description.
Thank you for the help.
  #558
Old 12-19-2016, 04:15 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Seller listed the part number:
E8HZ-2310-A .. Bracket Kit-Brake Camshaft-Right Rear / Obsolete
1988/89 F700/900 with Bendix 16 1/2" x 7" air brakes.
Last MSRP: $660.85 - Dealer net cost: $429.55 / The ebay price is a roaring bargain, but the parts catalog description is a bracket kit, but I only see the bracket.
But, if the truck does not have this type of air brakes, this is the wrong part number.
  #559
Old 12-19-2016, 04:18 PM
psmith0803's Avatar
psmith0803
Thank you for the warning! I'm going to double check the picture of the part against the part to make sure.
I appreciate all your help! Have a great day.
  #560
Old 12-23-2016, 07:58 AM
tonymontanna1983's Avatar
tonymontanna1983
tonymontanna1983 is offline
Can you decode this one for me?
60ccej8815
146 F607 Ga8 A 65j
19700 150454
Thanks!!
  #561
Old 01-08-2017, 10:11 AM
NumberDummy
F60CCEJ8815 / WB: 146 / COLOR: Blank* / TYPE/GVW: F607 / BODY: GA8 / TRANS: A / AXLE: 65J / MAX GVW LBS: 19700 / DSO: 150454
F60 = F600 2WD (gas).
C = 370 2V or 429 4V
C = Oakville Ontario Canada Truck Assembly Plant.
EJ8815 = 1979.
146" Wheelbase.
COLOR: Blank*
F600 2WD (gas), 19,700 lbs. GVWR
GA8: GA = Black Heavy Duty Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
65J:
65 = Rockwell Single Speed Rear Axle / 6.83-1 / 15,000 lbs. Rear Axle Capacity.
J = Ford 5,000 lbs. Capacity Front Axle with P/S or Ford 4,700 lbs. Capacity Front Axle with M/S
19,700 lbs. Gross Vehicle Weight Rating.
150454:
15 = Newark NJ Ford District Sales Office, where the original selling dealer ordered the truck from.
0454 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
*When there is no COLOR code, truck painted a non standard color per the original purchasers order, making it a Domestic Special Order.
  #562
Old 01-22-2017, 10:40 PM
cgolden9's Avatar
cgolden9
cgolden9 is offline
1998 F-800
Can you decode this Vin for me:
1FDWF80C9WVA21907
  #563
Old 01-23-2017, 08:49 AM
Destroked 450's Avatar
Destroked 450
Destroked 450 is offline
It's called a bracket kit because it includes the two inner bushings and grease seals, I can see the grease seal and bushing is behind the seal, don't know if he got it but that is the correct bracket for a S cam air brake.
  #564
Old 01-29-2017, 10:38 PM
tonymontanna1983
Thank you numberdummy!! Your services are not taken for granted!!!
  #565
Old 02-10-2017, 10:33 AM
gdoakes's Avatar
gdoakes
gdoakes is offline
Vin/Info Tag decode 1985 F700 Dump
Posted this in the top of the forum but will cross post it here in hopes that NumbersDummy will see it and decode it for me.
Picture of Vin/Info tag are attached.
I've decoded the vin using other tools and it comes up as an LN7000 which is flat wrong so I'm coming here to get it decoded correctly and confirm which A/T type/model is in it and what axle ratio it has.
1985 F700, 8.2L GM/Allison w/ A/T (Allison but which model)?
Thank you in advance.
  #566
Old 02-10-2017, 03:40 PM
NumberDummy
Decoded in your other thread.
  #567
Old 02-17-2017, 12:23 PM
shillinghillf600's Avatar
shillinghillf600
shillinghillf600 is offline
N850
Hello Bill, im working on a 1969 N850 , I'm looking for the driveshaft carrier bearing, I found a part no.
D4HZ-4800-A, could you check to see if this is the right number and if this part is available anywhere.
Thanks, Bill
  #568
Old 02-17-2017, 12:31 PM
NumberDummy
Originally Posted by shillinghillf600
Hello Bill, im working on a 1969 N850.
I'm looking for the driveshaft carrier bearing, I found a part no. D4HZ-4800-A, could you check to see if this is the right number and if this part is available anywhere.
I don't have this part number listed, it was probably replaced. I need to know which trans your truck has.
If you aren't sure, post the TRANS code stamped on the Warranty Plate, riveted to the left door face below the latch.
  #569
Old 02-17-2017, 12:48 PM
shillinghillf600
N850
Thanks for your quick response, the vin is N861LUE13318 trans code is blank but I'm sure it's a Transmatic MT-42, axle code is BKE, DSO is 549493. Thanks for your efforts, Bill
  #570
Old 02-18-2017, 11:46 AM
NumberDummy
Transmatic not listed for an N Series. The only way I can help you is if you list the diameter of the bearing.
Quick Reply: OLD DECODES
