7.3 diesel just cut off
Old 06-23-2011, 11:38 AM
chopman's Avatar
chopman
chopman is offline
I'm new at this so bear with me, I have 2001 F-450 7.3 diesel. Driving the other day and the thing just cut off. Waited, started up got home and died again. The electric fuel pump (under hood) I replaced. But know it won't stay started. No fuel is staying in the motor. Doesn't make sense.
Old 06-23-2011, 01:28 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
the fuel pump is on the frame rail under the cab. check the fuel filter and fuel psi.
Old 06-23-2011, 06:50 PM
badhabit1's Avatar
badhabit1
badhabit1 is offline
Think you were messing with the fuel filter under the hood? Pump is under vehicle. Random stalling and restarting sounds like a classic CPS (camshaft position sensor) issue. This is a cheap and easy replacement part and common to fail. Could also be ICP or IPR. Or, I suppose, as you stated it could be the fuel pump. But, I doubt it.
Old 06-23-2011, 06:52 PM
badhabit1's Avatar
badhabit1
Oh, also is your oil full? How old is the oil? 7.3's get a little finnicky with their oil!
dahr85
290
01-23-2024 07:24 PM
Hawaiianbobby
09-21-2015 08:58 PM
tomherrick
18
05-27-2011 04:18 PM
Quick Reply: 7.3 diesel just cut off
