EFI Supercharged 460!
  #61
Old 11-06-2013, 07:12 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
There is no harness to make this work, you need to make it yourself. You need to get another ECU connector from another truck, and remove the pins from it to get the extra pins you need.
It's not hard, just need to be careful and take your time.
  #62
Old 11-06-2013, 07:26 PM
arod1256's Avatar
arod1256
arod1256 is offline
Ok I was mistaken then , I thought I could get one off a 94/ 95 maf e4od lightning and work into my harness... or the other route http://www.rjminjectiontech.com/coll...to-maf-harness . But if you could further direct me in the way u performed your conversion it would be of great help.. any pictures ??
  #63
Old 11-06-2013, 09:45 PM
4.9L's Avatar
4.9L
4.9L is offline
Bad *** rig
  #64
Old 11-06-2013, 10:35 PM
Lead Head's Avatar
Lead Head
Originally Posted by arod1256
Ok I was mistaken then , I thought I could get one off a 94/ 95 maf e4od lightning and work into my harness... or the other route RJM Injection Tech — Truck SD to MAF Harness . But if you could further direct me in the way u performed your conversion it would be of great help.. any pictures ??
There's no such thing as a MAF lightning.
We basically manually made that harness you linked. Pictures aren't really going to help unfortunately.
Basically what you need to do is look at the pinouts for the 460 E4OD truck, and then change it to the 94-95 E4OD Mass-Air 5.0 computer pinout. Ford Fuel Injection has all the pinouts.
Your injection harness is bank fire, meaning it fires half the injectors at the same time, so only has two injector wires. You need that conversion harness to add the MAF wires and the extra injector wires.
  #65
Old 11-07-2013, 10:58 AM
arod1256's Avatar
arod1256
arod1256 is offline
Lead Head : would this work for my application ?
AKC0 5.8 1993-95 Lightning MAF / E4OD / F8TF-12A650-NA
and i know it will need to be tuned
  #66
Old 11-07-2013, 07:57 PM
Deerediesel's Avatar
Deerediesel
Deerediesel is offline
I found a FEZ3 PCM for my truck. That's a '96-97 460 with MAF and California emissions . It's Ecc V, and 104 pin.... Got a PCM pigtail from an '01 expedition , some pins will have to be removed and some added in. Paid about a ridiculous $600 for the overlay wiring harness. No instructions included, so I got my Haines manual and started reading wiring diagrams...
  #67
Old 11-07-2013, 08:01 PM
Deerediesel
If I had to do all this over again I prob Would have just went with an aftermarket fuel/ignition controller such as moates or mega squirt .
  #68
Old 11-07-2013, 08:27 PM
Lead Head's Avatar
Lead Head
Why do you keep looking for lightning computers? The only MAF lightning computer was one offered by FRPP as a conversion kit. They're pretty rare, and you won't be any better off by getting one, as it still won't run your 460 without tuning.
You need a 94/95 F-150 California 302 E4OD computer with the catch code HOG0, HOG1, WAY1 or VEX1.
You're going to need the computer, the mass-air conversion harness (or DIY), and a tuning shop. If you're running a pro-charger, you're going to need the mass-air sensor before the throttle body, after the super charger.
  #69
Old 11-07-2013, 08:42 PM
BleednBlue68's Avatar
BleednBlue68
BleednBlue68 is offline
Very nice! I want to drop a 460 in my 58 f100 panel truck. Have you guys seen the boss 429 conversion kit you can do to the 460? I want that!!
  #70
Old 11-08-2013, 06:42 AM
Deerediesel
I actually have a MAF computer for a '95 302/351 laying around here somewhere.... I'll see if I can find it and get the box code. I'm prob never going to use it, as the truck I had bought it for ended up getting stripped and a carburetor now sits on top...I also have an '86-88 mustang MAF conversion PCM ( just the PCM and MAF sensor) ...saw where somebody had a 460 w/ C6, I think his best route would be early mustang PCM such as this or A9L....much much simpler conversion When not dealing with the E4OD
  #71
Old 11-08-2013, 11:02 AM
arod1256's Avatar
arod1256
arod1256 is offline
Ok Thanks Lead Head , I have been looking for the computers you have recommended. What year of truck did you get your harness from i may go the same route you did and just wire it in to mine . How difficult was the repinnig for you ?
  #72
Old 11-08-2013, 11:03 AM
arod1256's Avatar
arod1256
arod1256 is offline
DEERE diesel , please let me know i would be very intrested .
  #73
Old 11-08-2013, 03:25 PM
arod1256's Avatar
arod1256
arod1256 is offline
Lead Head, would a 90 mm MAF sensor off of a 2001 lightning work i have a brand new one that i would like to use on my build or the compatible with the ECM you have recommended ?
  #74
Old 11-08-2013, 05:04 PM
Lead Head's Avatar
Lead Head
I didn't get my harness from any truck, I just added the wires I needed to. I'd recommend you get that harness kit you linked. It will greatly simplify your task.
A lightning MAF is not ideal in a blow-through application. I'd recommend a slot-MAF. I'd recommend a PMAS HPX.
  #75
Old 11-10-2013, 02:52 AM
eagle275's Avatar
eagle275
eagle275 is offline
Ok guys, I have a Vortec supercharger I need to get rebuilt for my 96 F350, 460cid,C6 wGear vendor,std cab LB, and set it up like the kit that used to be sold a few years ago for our trucks. Main thing is to get centrifugal supercharger rebuilt and go from there. Can you guys help me out? A retired combat vet who would really like to finish this project. Willing to redo heads, cam,etc. Got headers ready the other day. Being painted right now.
Quick Reply: EFI Supercharged 460!
