Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
bus frame fit a f600 ford truck
Old 06-20-2011, 09:12 PM
cturner41314's Avatar
cturner41314
cturner41314 is offline
will a bus frame fit a f600 ford truck?
Old 06-20-2011, 09:49 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,669 Likes on 1,362 Posts
Was it an F series bus? If so, the cab may bolt to it, and then you can deal with the rest. I would think the bus would be a fairly long wheelbase compared to the average F600. If that is the case, I don't see this making sense.
What year/model bus? What year F600?
Old 07-01-2011, 09:43 PM
wmjoe1953's Avatar
wmjoe1953
wmjoe1953 is offline
The short answer is yes, depending on the vintage of body. Most all larger truck frames, including Ford, GM, Dodge, Freightliner, Peterbilt, Kenworth, Mack, etc., use a 34" wide frame rail, out side to out side. That is the most universal frame rail width for transplanting a body onto another chassis. Also, most all of those larger frames, are straight frames, meaning, that very few of them have notches, or kick-ups for axles, and such. They are the absolute best thing to use when transplanting a body for any larger truck projects. The only real issue will be in fabricating the body mounts, unless it is an older body, like from the 60's, and earlier. Most of them had fairly straight forward frame brackets. Also, there are a number of reasons for such a long wheel base, including crew cabs, big sleepers, tons of custom mounted chrome, and stainless goodies, and multiple rear axles.
flipklos
08-09-2012 10:07 PM
55 Bus
09-24-2010 04:19 PM
b600jake
New Member Introductions
09-04-2007 06:17 PM
Quick Reply: bus frame fit a f600 ford truck
