1966 ford 390 to 390 gt heads
Old 06-17-2011, 08:33 PM
ford79man91's Avatar
ford79man91
ford79man91 is offline
I have a 390 i am currently rebuilding and wanted to put my GT heads on. Without cutting off the old header flanges how could i go about modifying my flanges to make them work, gts are the 14 bolt exhaust current header flanges have the two vertically opposed, just wondered if anyone modified before????
Old 06-18-2011, 10:44 AM
travelerest's Avatar
travelerest
travelerest is offline
GT heads made for the mustang, cougar and fairlane which has the extra diagonal holes, have the same vertical holes. You do not need to modify anything.
Old 06-18-2011, 12:37 PM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
Not always true. Normally the GT heads with the 14 bolt pattern (C7-C8) are missing the lower bolt holes on the 2 center exhaust ports. The heads can be drilled and tapped for the bolt holes but have to be carefully done. Or you'll see water. That said depending on which casting number they are they are somewhat sought after in the 14 bolt pattern to some restoring GT S, X code and 67 Shelby cars. Later service heads all had the 16 bolt patterns to cover all exhaust patterns.
Old 06-18-2011, 12:49 PM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
Ford casting ID numbers and part identification info for Mustang Shelby parts shows pics of the C7 and C8 14 bolt heads under the heads section to see the differences. That said the GT/Shelby C7-C8 heads are not all that special nor different (other than the exhaust pattern) from other C7-C8 heads. In fact if you currently have the C6AE-R heads they are a better option IMO. Unless they are beat to death with issues. But please let us know what casting numbers of the heads are to better answer your Q's. C8's also have a lowered exhaust port which can be a problem with sealing some headers.
Old 06-18-2011, 02:37 PM
maxtor's Avatar
maxtor
maxtor is offline
He needs to look at his heads and see if he has all the vertical holes. Or he needs to purchase some 428cj/sjc heads like the below.
2008_1104Image0003.jpg picture by Maxtor427 - Photobucket
Old 06-18-2011, 03:37 PM
ford79man91
i have the c6ae-R heads and my current heads and headers have the two vertically opposed bolt holes and the GT heads have the 14 bolt holes outside ports have 4 bolt holes and the inside two ports have three bolt holes. I was told someone may make an adapter?? but i dont know i have not found anything on the Web.
Old 06-20-2011, 10:33 PM
68fordshortbed's Avatar
68fordshortbed
68fordshortbed is offline
On my 390 i have the same number heads C6AE-R off a 66 mercury cyclone GT i had to modify the heads to get my headers to fit i drilled and tapped the holes and stuck a bolt in the ones not needed and cut it off and smoothed it down flat so it would all seal i have had no problems. but do remember dont drill to deep you dont wanna hit water!
meck1
1983 - 2012 Ranger & B-Series
08-05-2016 04:25 AM
Macmathews
07-11-2016 10:43 PM
AXracer
33
09-04-2015 09:25 AM
Kuvrok
12-30-2014 09:03 PM
wildwes
07-05-2008 11:18 PM
Quick Reply: 1966 ford 390 to 390 gt heads
