Bad strange noise form engine
Old 06-07-2011, 12:19 PM
redman84's Avatar
redman84
redman84 is offline
bellhousing bolts nice and tight?
Old 06-07-2011, 03:42 PM
arkredneck's Avatar
arkredneck
arkredneck is offline
I'll check bell housing bolts already checked torque convertor I'll check dp again
Old 06-07-2011, 05:53 PM
arkredneck's Avatar
arkredneck
It's difenatly sounds like it's coming from the torque convertor
Old 06-07-2011, 08:41 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Cracked Flex Plate?
Old 06-07-2011, 09:03 PM
arkredneck's Avatar
arkredneck
I didn't check that but will sounds like a rattle and clunk and grind all together but still goes away
Old 06-08-2011, 05:56 AM
DIYMechanic
Yeah, check the flex plate real good. You may have a cracked one. They can make some really strange noises when they are on their way out and you DON'T want to let it go until it comes apart.
Old 06-08-2011, 07:37 PM
arkredneck's Avatar
arkredneck
Well I can't seer nothing wrong with flex plate so I took the dp off still has a noise so I guess I'm gone pull the trans and see if my noise Is motor or trans I'm gonna be mad once I do it and find that it's something stupid simple
Old 06-08-2011, 08:38 PM
DIYMechanic
Does the truck make this noise in all gears? Reverse, Neutral, etc?
Old 06-09-2011, 07:43 AM
arkredneck's Avatar
arkredneck
Yes and park just idling it will go away when the engine has a load
Old 06-09-2011, 07:44 AM
arkredneck's Avatar
arkredneck
I really wish I could get a video Of it doing this I've parked it for now and am driving my other psd with 15" of lift and 42" tires to work I hooe it's simple
Old 06-11-2011, 10:19 AM
arkredneck's Avatar
arkredneck
Thanks guys I found the noise the flex plate is completely broke in 2 pieces atleast it wasn't the engine 342000 miles so I can't complain to much
Old 06-11-2011, 01:39 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Wide Open Performance has cyro treated flex plates available if you want to go in that direction.
  #28
Old 06-11-2011, 06:08 PM
arkredneck's Avatar
arkredneck
Thanks but I had a extra one my 97 crew cab 4x4 started as a auto and I tore the zf5 out of another 97 I got and put in it so I had a spare e40d and really a whole spare parts truck I got 3 of these things really wish I could post pics for yall
  #29
Old 06-11-2011, 09:27 PM
rodneywar's Avatar
rodneywar
rodneywar is offline
what year is the truck with the broken flexplate?
resq302
08-21-2018 10:29 AM
Billy Mack
2009 - 2014 F150
06-24-2016 07:46 AM
1982_f150
15
09-05-2008 11:49 PM
Corry van Viersen
19
12-15-2005 12:10 AM
tcmullenix
03-02-2002 07:52 AM
Quick Reply: Bad strange noise form engine
