Sponsored by: Real Truck
Load question
Old Jun 4, 2011 | 07:35 AM
alty79's Avatar
alty79
Load question
I have a 2004 F250 FX4. I need to pickup 2100 lbs of flooring. Can that be hauled safely in the bed or should I split the load with a trailer?
Old Jun 4, 2011 | 07:40 AM
1996pwrstrk's Avatar
1996pwrstrk
That should be NO problem with that little bit of weight It will just ride really nice, you shoudn't need a trailer.
Old Jun 4, 2011 | 07:42 AM
sawtooth's Avatar
sawtooth
Your truck should be rated to hold that much as long as you don't have a lot of other stuff and people. I think around 2500lbs is max in those F250's
Old Jun 4, 2011 | 07:43 AM
senix's Avatar
senix
you can load as much as your tires will stand. Always good to know your empty weight so then you know the remainder that can be added.
catscales.com
$9.50 last time I did mine.
Old Jun 4, 2011 | 08:16 AM
alty79's Avatar
alty79
Thanks for the quick replies guys, I am picking up 37 boxes of 7 foot length flooring. It has the 8 foot bed. Just want to be safe hauling it since it is a company work truck. Would it be better to haul some in the bed and then some on a trailer? (because of the amount of boxes)
Also, no one else will be riding and I won't be hauling anything else, just myself.
Old Jun 4, 2011 | 08:22 AM
alty79's Avatar
alty79
I am running Firestone Transforce AT tires 225/75-R16. Load Range E. Says they are rated at 2680 lbs each.
Old Jun 4, 2011 | 08:49 AM
dchamberlain's Avatar
dchamberlain
I used to carry a 3000 pound slide in camper in my 2004. It wasn't a problem. I've also carried 1 ton of wood pellets on a pallet. Air up your tires to 75-80 PSI each and load the boxes as far forward as possible and I doubt you'll have any trouble.
Old Jun 4, 2011 | 09:18 AM
senix's Avatar
senix
5360 is your max so I think you are ok, but right at the limit.
Old Jun 4, 2011 | 11:53 AM
1996pwrstrk
He does have 4 Tires on this truck so it would be 10720 If all 4 tires are rated the same . Only 2100 lbs spread out over the whole bed floor it might set it down a little but not much He shouldn't have any problem . I have hauled way more than that in mine I know mine's a F350 but there very little difference between the 2 .
Old Jun 4, 2011 | 10:06 PM
Gordon-0's Avatar
Gordon-0
thats a rather low rating for tires.
mine are 3400 if i remember right.
you cant just divide load by 4 to get safe rating for tires.
OP, invest in some better tires.
i have seen more than 4000lb in bed of a superduty.
dont sweat it.
ive had about 2500lb back there and it rode NICE
Old Jun 5, 2011 | 07:06 PM
adam10's Avatar
adam10
yeah 2,100 pounds is nothing for it. i have a 99 250 and i haul 3,000 pounds of coal 4 times a year.just the other weekend i went to get pavers they said 120 to a pallet@ 30 pounds a piece turns out when i unloaded them there was 150 on a skid.at 4,500 pounds i wouldnt want to haul that much all the time though.
Old Jun 5, 2011 | 08:48 PM
03F350XLT's Avatar
03F350XLT
His load index is lower due to the fact he's running 225s rather then 265 or 285/75/16 still e range but lower rating due to the smaller size. None the less that 250 can take that load no problem.
Old Jun 5, 2011 | 11:31 PM
Winnipeg's Avatar
Winnipeg
Good points about checking the tires for their ratings. It should have load range "E" tires, but it may have gotten some "D's" put on it. That would decrease the load capacity, and its pretty safe to assume that all of the load will be on the rear tires (unless he plans on putting some boxes on the hood).
One other point to consider, the truck has a legal GVW limit. The 4x4 gear and diesel engine (if it has PSD) eat up a lot of the GVW before you even sit in it. Its nice to know your truck's empty weight, GVW and tire ratings. Once you know them, you can make an imformed decision on what is safe to carry.
Old Jun 6, 2011 | 05:13 AM
senix's Avatar
senix
Exactly! That was what I was getting at early on in this thread. Know your current weights, know the capacities for the axles and the tires.
Work within those safe limits. If you find that you need more, get a trailer or better tires.
