need help
Old May 3, 2011 | 08:44 PM
DOWN-N-DIRTY's Avatar
DOWN-N-DIRTY
need help
for past few months i have replaced the #2 injector 7.3 psd .
ran good for a bit .
replaced all wiring on driver side
had neighbor take to ford guys and the started research
say #2 is miss fire again(poss scratched or damaged o-rings)
# 8 has an issue? unknown just porblem signal
truck when started from cold blows out light blue to white smoke and smells like unburned fuel
when driving clears up and runs smooth
when turned off or get to idle, feels like a miss- lopes.
2001 f-350 4x4 lariat
please help if you might know
thanks in advance
Old May 4, 2011 | 07:37 PM
Ultramagdan's Avatar
Ultramagdan
Moved to proper forum.
Old May 4, 2011 | 07:58 PM
F350-6's Avatar
F350-6
Welcome to FTE. I'd skip over the #8 issue for now since that's fairly common on these motors. Did you use a new or rebuilt injector for #2? What brand o-rings did you use with the injector? We've seen aftermarket o-rings fail that quick.
jamer
1983 - 2012 Ranger & B-Series
Feb 3, 2015 07:26 PM
caseihpuller88
26
Apr 27, 2013 09:47 PM
TWDITMORE
1997 - 2003 F150
Dec 3, 2011 09:50 AM
CLR
Nov 29, 2010 06:41 PM
Drunkiner2
Nov 30, 2001 07:00 AM
