Lifted Our Excursion
Thanks to YellowSled for the great write up - https://www.ford-trucks.com/forums/8...ims-tires.html
Before:
37 inches to the middle of the front wheel well, 39 in the rear.
The job took two of us 6.5 hours using two floor jacks, two 12 ton jackstands and an air impact.
Took the wheels off and removed the front shocks. To get the front springs off you have to remove the bumper.
ProComp 22210 spring. I used Bilstein 5100s for the shocks.
My 1 1/2 year old son helping us get the spring in place.
In the rear I used a tapered 2" block under the stock block. I have Bilsteins for the rear, but did not have the shock bar pin so I kept the stockers on for now.
After:
41 inches to the middle of the front wheel well, 41 in the rear. This is with worn out 265 BFGs.
New tires are going on this week. Either 295 or 315 BFG ATs, I haven't decide yet.
Before:
After:
I looked at the 305s but I am concerned with the width and rubbing on the springs during a full turn.
I would say I'm sorry for saying this, but I'm not. If you lived closer to me I would take an aluminum baseball bat
and knock you into Unconsious Land. While the image is adorable, accidents happen in a split second.
OK, got that off my mind! Truck looks good.... after you get larger tires mounted!
