Recently i have had problems with the driverside head light. I do not have low beam or a day time driving light. It is only on the driver side. I checked the wiring and it is not damaged. I also installed a new light bulb. Any suggestions on what else i can check?
Check fuse 7 at the smart junction box (fuse box) on the right side kick panel. It is a 10 amp fuse for low beam. If that fuse is OK and wiring all OK then you may have to replace the smart junction box. Hopefully you just blew a fuse with a bad bulb.
I checked all the fuses with a test light and followed the wiring back from the headlight to the main harness and could not find anything wrong. Thank you for the help.
