The camper thread! Pulling, using, equipment, maintenance!
#3736
I like the word retired much better. I'm really glad you are able to weather this without too much difficulty.
#3737
#3738
They get water inside every year. I pull the cap, use a hypo grease needle and go through the upper bearing into the cavity and pump/keep them full of grease. Water always comes out. Marine grease is really a good option with water issues and bearings.
#3739
Holy smokes Eric, that bearing is toast!
Back when I bought my Hensley used it had a wet bearing from a dented cap, I replaced that one and another that just didn't look or feel "right" and they have all been dry and OK the few times I've peeked at them over the years. I think this Winter I will be pulling them all to give the hitch a much needed repaint.
What do you think about the new 7.3 gasser and 10 speed? I can't wait to read some towing reports once they are finally in the hands of users.
I like the term "Pre-tired", I will retire once she does and we can hit the road!
#3740
#3741
I think a lot of the 7.3 10 spd combo. Good chance one will be in my driveway next spring.
#3742
#3743
The drop point on most marine grease is 500 deg.
Switched to Lubrimatic 11402 marine grease which has a drop point of 550 deg and no more issues.
#3744
#3745
I had been using regular marine grease on our boat trailer, but on very hot days & winding roads the disc brake axle would blow off the caps and throw grease all over.
#3746
Another cheap option if you don't need 14oz is Hobo Freight: https://www.harborfreight.com/marine...ase-97844.html.
#3747
#3748
#3749
#3750
