1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Tire Size
Old 04-20-2011, 08:55 PM
RacerXtreme's Avatar
RacerXtreme
RacerXtreme is offline
Tire Size
Just picked up a very low mile 2004 F250, with the 6.0 PSD. The truck looks great, but the tires and rims are gonna have to go...! Can anyone tell me the largest size rims & tires I can go to without lifting the truck?
The truck has a towing pkg and the FX4 option so it sit's up pretty high now. Any ideas would be great.
thanks
Old 04-20-2011, 09:08 PM
lakedweller's Avatar
lakedweller
lakedweller is offline
A member with a 2011 says he can fit 35" on his truck without lifting. Guys at tire shop can help determine the biggest tire you can put on your truck.
Old 04-21-2011, 01:42 AM
Roadfind's Avatar
Roadfind
Roadfind is offline
I have two sets of tires on stock wheels . 285s don't rub the 315 rub only on the right side on full lock ,it only touches the leaf springs not any body parts, my truck has a front leveling kit . My brothers SD same year same 315 with a after market wheels that have about 1.5'' more back spacing than the stock wheels and does'nt rub at all . OllllllO
Old 04-21-2011, 02:43 AM
Sparky04SD's Avatar
Sparky04SD
Sparky04SD is offline
I've run 315's on my 04 since buying it in Dec 03. Never had a problem, eventually installed a leveling kit and gained another 1/2" clearance on the front tires. Wheel offset is critical and I use 16 x 8's with 4.25" back spacing. You could get away with 4.5" back spacing but anymore and you could have clearance issues. I do have 315's on 16 x 10's on my Excursion with a 3" lift kit that sits at same height as my F250. Back spacing on these are 4.5".
acwatkins
28
03-31-2016 05:23 AM
Byron West
10-21-2015 04:18 AM
MJFNH
2009 - 2014 F150
06-23-2015 06:29 PM
2000gpr
2004 - 2008 F150
04-09-2008 09:56 AM
Turnbury95Ranger
1983 - 2012 Ranger & B-Series
12-30-2006 06:19 PM
Quick Reply: Tire Size
