Trying to adjust the TV cable so it will downshift into low gear, just hoping it's a too much pressure issue. I don't want to be pulling a transmission again..
No I cut the cable off later, throttle and TV cable are LOKAR products. I think I may have found the problem, might not have been enough tension on the return spring for the throttle, just waiting to test drive if the storm clouds pass over..
