2003 F-150 - Degree C to Degree F???
Old 03-18-2003, 06:37 PM
pmm026s's Avatar
pmm026s
pmm026s is offline
Just bought a 2003 F-150 Lariat and it has the electronic automatic temp control (has digital read of temp in car and outside instead of normal ***** for temp control). But, it's in degrees C and I need it in degrees F. I've called the service dept. where I bought it and they couldn't tell me over the phone for some reason. If anyone knows how to do it, I appreciat the help. I've read the entire manual and can't find how to do it anywhere.
Old 03-18-2003, 07:59 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
A couple months ago I was PDI'ing a new truck and had to change from F to C. I couldn't find the info anywhere so I called Ford's Technical Hotline and they told me how to do it. It can be switched between C° and F° display readings by pressing the MAX A/C and DEFROST buttons simultaneously for at least 1 second.
Old 03-19-2003, 11:33 AM
pmm026s's Avatar
pmm026s
pmm026s is offline
Thanks for the info. I'm at work now, but I'll see if that does it. Man has that been bugging the hell out of me. Thanks again.
Old 03-19-2003, 12:17 PM
pmm026s's Avatar
pmm026s
pmm026s is offline
Worked like a charm - thanks a bunch. Man that was buggin' the hell out of me. Why wouldn't they put that in the owner's manual? Makes me wonder how much other stuff I can do that I don't know about.
Old 03-19-2003, 02:23 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Yeah you really do have to wonder why Ford wouldnt put that info in the owner's manual. I asked all our salesmen and they had no idea and I couldnt find it in the manual. It took Hotline about 10 minutes to find someone there that knew how it was done.
Just another one of those good Ford things
