Auto Transmission Shifting Issues
#286
With only 5K on the truck & no towing to date I'm experiencing a rare 2-3 upshift that seems to take too long and over-revs a few hundred rpm, though not as severe as some reported here. Also have noticed occasionally when applying throtttle while rolling - say when a light goes green just before you stop - throttle response seems delayed then kicks you back in your seat. Neither event is frequent or problematic yet but when I took the truck in for an oil change I asked the tech to look into the TSB reported here. He replied that he'd need to verify that the truck was truly experiencing the problem called out in the TSB before he could do anything. I understand.
What he came back with was that they need the truck for three days to pull three solenoids out of the tranny, check serial numbers of the parts with FOMOCO, and then possibly change the solenoids and/or procede with the flash. Sounds a bit different than most of what I've seen posted here. Anybody else run into anything similar?
#287
That Sounds like TSB 11-5-19 Which is for the 6.2 - That was the procedure with my gasser - They pulled the pan - got the correct solenoids overnight & I got the truck back the next day...
I may be wrong but I didn't think that they were pulling the solenoids on the 6.7's.
But - I've been wrong before....
#291
It is amazing this problem has gone on so long.
Several with the same issue and all we customers want is a fix.
I drive with manual mode most of the time because I like this truck so much I can't leave it parked in my driveway.
The dealer and I are at the point where either I start paying for an attempted fix or the dealer pays out of pocket for a fix, which neither of us want to do nor do I expect the dealer to do.
They didn't design the truck.
Someday...
Someday...
#292
Needs to be fixed
The transmission seems to be the week point on 6.7 truck.
I WANT ford to fix this so I can have a 6.7. I just don't understand why Ford has not put in the real fix yet. They must know why, and how.
I was hoping this one would be the fixed by now.
Does keeping the truck in manual mode prevent this????
#293
#294
I've had more success (but can still occur) shifting below 1,500 RPM but it clunks into gear so I don't like it but it's better than clunking into gear at 2,500+ RPM because it high revved when unable to locate 3rd.
After it happens, all is well and I return back to my 1,800 RPM or so shift points.
The transmission seems to prefer shifting around that RPM.
Also shifting into 3rd multiple times at low speed (say leaving the subdivision or office) won't prevent it from occuring.
It's as if the TCM programming has to allow this failure for all to be normal again and getting into 3rd ahead of time doesn't clear it.
The TCM learns about good shifts and bad shifts and shouldn't repeat the bad shifts but something is preventing that bit of information from being interpreted correctly.
I know we won't see it but I'd certainly listen if an engineer were to explain what is going on between the programming and hardware when this issue occurs when they finally figure it out.
#295
Been going on long enough. My truck has spent more time in the shop getting diagnosed and worked on that I have driven it. My truck is being the guinea pig from the dealer I bought it from and all the other customers are holding off until they see if they can get mine fixed first before they waste their time bringing theirs in.
#296
#297
My F350 4x4 Crew Cab is 3/15/2011 manufacturer date and I had my servicing dealer apply the latest TSB released in late April.
I have been in our NC Mountains this past week on paved roads up to 6200 feet elevation and on unpaved rough access roads down into Linville Gorge.
I was very pleased with the way the transmission performed and the downshifting breaking on steep descents is greatly improved over my 2008 F250. There were not many times I had to coax the transmission into a downshift. Uphill shifting was smooth also. The truck handled the steepest of inclines with ease and smooth shifting on high summit roads.
Overall I say the new transmission performs better under these conditions than in an in town situation where it is more apparent the truck is getting into higher gears at lower rpms without shifting to a lower gear as quickly as my 2008 when traversing hills down in the piedmont.
#298
#299
Someday...
Someday...
