1978 - 1996 Big Bronco
Code 67 HELP
Old Mar 15, 2003 | 02:41 PM
Kallie's Avatar
Kallie
Question Code 67 HELP
I have a 89 302 auto 4x4 and seems to runs fine with a little hesitation while idleing but it is rare. My check engine light has been blinking since I bought it 3 weeks ago. We checked and then cleared the codes last week. Then they read 15 11. So we noticed it was blinking more so we had to wait for dry weather and read them and it read 67 67. I have checked it on the code list I have and it has 3 possiblities. None make sense to me. Could someone please tell what needs to be fixed. I do have A/C and it is not running. I did check.
Neutral/drive switch open or A/C on
MLP sensor out of range or A/C on
clutch switch circuit (E40D)failure
Thanks,
Kallie
Old Mar 16, 2003 | 02:09 PM
Kallie's Avatar
Kallie
Code 67 HELP
Someone must know something.
HELP HELP
Kallie
Old Mar 16, 2003 | 02:13 PM
83bigbroncoguy's Avatar
83bigbroncoguy
Code 67 HELP
I don't think the AC would have anything to do with the truck not running right. Check the EGR and O2 sensor. The O2 sensor on my '86 caused it to idle a litle rough.
Old Mar 16, 2003 | 06:58 PM
steve83's Avatar
steve83
Code 67 HELP
Here's my list - are you sure you're pulling & reading the codes correctly? The Haynes manual has the best instructions I've found, and a fairly good code list, but it's not complete or organized intuitively.
