I'm completely stumped
Old 03-12-2011, 06:51 PM
richdawg's Avatar
richdawg
richdawg is offline
Originally Posted by Dvandy21
Hey guys, first I just wanted to thank you all for all of the good advise. I did some testing today with the voltmeter and sure enough the GPR wasn't working properly. I had a spare one, so I hooked that one up and it too wasn't working. I checked the ground and it turns out it was getting a bad ground. I got the problem all taken care of, so I cant be sure til the morning, but the GPR should now be working properly.
If you think you got the problem all taken care of, you shouldn't have to wait till morning. If your in State College, PA your temp was about 50 today, thats usually good starting temp if things are working right.
  #32
Old 03-13-2011, 09:42 AM
Copedawg's Avatar
Copedawg
Copedawg is offline
Well? What happened this morning???
  #33
Old 03-13-2011, 12:08 PM
Dvandy21's Avatar
Dvandy21
Dvandy21 is offline
It started right up this morning! I'm so relieved, this has been the biggest PITA for the last few weeks. Fixing the GPR was all it took. Thanks again, guys, for all of the good advice, couldn't have done it without you.
  #34
Old 03-13-2011, 12:16 PM
Copedawg's Avatar
Copedawg
Copedawg is offline
Good to hear Dave!
Don't be a stranger, see you around!
  #35
Old 03-14-2011, 05:39 PM
Dvandy21's Avatar
Dvandy21
Dvandy21 is offline
Well I guess I'm not quite out of the woods yet. The truck wouldn't start today. I hooked up the volt meter and one of the large posts is registering 12.8 volts as it should. The large post with the two wires coming out of it (which go to the plugs, correct?) is registering 0 volts. That's with the key turned to the "on" position and the "wait to start" light on. The original issue turned out to be a bad ground, so we ran a wire directly from the negative battery terminal to the GPR. That seemed like it fixed the issue, it started yesterday morning when it was about 35*. This afternoon I went to start it for the first time today (it was in the low to mid 40's) and she wouldn't start. Any ideas why the one large post would be registering 0 volts?
  #36
Old 03-14-2011, 06:21 PM
Action4478's Avatar
Action4478
Action4478 is offline
If you are using a GPR , (case isolated not a starter relay) the PCM sends ground to the GPR to time the GP's , based (mainly ) on EOT ...
So are you saying you fixed the no start with a ground wire ? Did you replace the GPR ?If you grounded the original , it is most likely burned out ..
No ground from the PCM can be a couple of things
  #37
Old 03-14-2011, 06:30 PM
Dvandy21's Avatar
Dvandy21
Dvandy21 is offline
Thanks Rick. I think I actually just solved the problem. Its reading volts now, I'll try starting it in the morning and see how it starts.
  #38
Old 03-15-2011, 02:15 AM
papa224's Avatar
papa224
papa224 is offline
dpeterson3
1983 - 2012 Ranger & B-Series
23
07-26-2015 09:22 AM
JW1971
1978 - 1996 Big Bronco
11-19-2014 11:09 PM
JW1971
11-12-2014 10:16 PM
tdel
01-08-2013 11:56 PM
ColdCougar
18
11-18-2007 05:13 PM
Quick Reply: I'm completely stumped
