Fuel Gauge works but reads way past full when filled and is empty when it reads 1/4
Old 03-09-2011, 10:57 AM
500FordF-150's Avatar
500FordF-150
500FordF-150 is offline
Any suggestions? I have a 1986 F-150 with a 5.0 AOD, the rear tank is not on the truck so I only use the front. The gauge works as far as incremently going down with use but when I fill the truck the gauge reads past full and when it is empty it reads there is still a quarter tank left,
Old 03-09-2011, 11:11 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Classic sending unit problem I would guess. If you got in the sending unit producing business for these trucks, you would have lots of business.
Old 03-09-2011, 11:15 AM
ri_truck_guy's Avatar
ri_truck_guy
ri_truck_guy is offline
Do your oil and temp gauges read high also? If yes, the Instrument Voltage Regulator (IVR) may be putting out too much voltage. That can be adjusted down. If it's just the fuel gauge reading high, it could be an issue with the the float itself. You caneleiminate the gauge and wiring as an issue by disconnecting the yellow/white wire at the sending unit and grounding it with the key in the run position. It should swing to full with the wire grounded and empty with the ground off.
Old 03-09-2011, 11:31 AM
Archion's Avatar
Archion
Archion is offline
If it is the sender they are available aftermarket for the EFI motors 19gal(60") midship tank as an assembly.
Old 03-10-2011, 07:54 PM
ic237's Avatar
ic237
ic237 is offline
if its your IVR here is a good one to use.
Ford Instrument Cluster Voltage Regulator 5v - eBay (item 280572904377 end time Apr-06-11 18:52:57 PDT)
Old 03-10-2011, 07:58 PM
ri_truck_guy
Originally Posted by ic237
I've had that one in my truck for about 4 months....it's every bit as good as advertised.
Bootlegger's Deluxe
26
07-01-2017 12:05 PM
bmxerbrett
05-31-2016 08:24 PM
joey2fords
Electrical Systems/Wiring
12-03-2015 06:29 PM
bill11012
03-19-2011 11:02 AM
FirstBronco
1978 - 1996 Big Bronco
13
10-20-2005 03:57 PM
Quick Reply: Fuel Gauge works but reads way past full when filled and is empty when it reads 1/4
