302 shakes at low idle
There could be (3) possible scenarios:
(O) - Key on Engine Off (KOEO)
(R) - Key on Engine Running (KOER)
(C) - Continuous Memory
1. 19 (R): Erractic RPM signal at Idle
2. 19 (O): Failure of PCM voltage regulator. Replace PCM.
3. 19 (C): CID sensor failure
More INFO: http://bronco.zenseeker.net/eec_iv_2_digit_codes.htm
19 (O) No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
(R) Erratic idle during test (reset throttle & retest) - Idle Set Procedures
Electronic ignition Cylinder ID sensor/circuit problem - Ignition Systems
If you are getting the Code 19 (R), It may directly related to your POST.
trevorrules
34
04-30-2017 05:34 PM
Broncoseth
1978 - 1996 Big Bronco
04-03-2015 09:24 AM
linus72
15
05-15-2012 04:13 PM
jodrayt
07-20-2007 11:47 PM
