Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
Location (State/Prov):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Item Condition:
1972 Chevy Custom 20
Old 05-04-2011, 10:57 AM
78pace's Avatar
78pace
78pace is offline
Year: 1972
Make: Chevrolet
Model: C-Series
Price: $11000
Mileage: 0
Color: Orange
Private or Dealer Listing: Private Listing
Location (State): WI
Transmission: Manual
Drivetrain: 4WD & AWD
Color: Orange
Engine: 515 cid
1972 Chevy Custom 20 4wd $11,000
Truck was pulled in the class between stock and super stock(class has different name depending where you are: street legal, improved stock, hobby stock) Truck already has all safety items any club would require. Fuel tank, electric fuel pump, 6 al MSD and coil are the only things not on truck.
-3” body lift
-Dana 60 front with 4:11 Detroit Locker (1yr. old)
-Eaton rearend with military style differential
-Muncie 4-speed with profab straight cut 3rd gear
-Additional stock Muncie 4-speed will come with
-205 transfer case has broken case that is currently in truck (old style Profab straight cut gears)
-Additional stock 205 transfer case will come with
-Aluminum driveshaft loops
-Weight rack for front of truck
-12.75x33 B.F. Goodrich Mud Terrain tires
-Lexon in front window, Plexiglas in back window
-Real glass in doors
-Hand throttle is currently installed (old gas pedal is still installed)-
-2 disc McLeod clutch still at original shims
-Dash mounted switches and start button from JEGS
-Phantom gauges (tach, fuel pressure, water temp, oil pressure)
Engine(800 HP)
*515 cu., Mark IV 4-bolt main with GM crank and caps, block has been bore aligned and is internally balanced, sfi approved balancer
*Cast Iron Heads, Merlin VR race heads-Heads have been ported; titanium valves with a sportsman shaft mounted rockers; custom tall valve covers
*Edelbrock Victor Jr. intake with a Holley 850 HP carburetor with a spacer
*CSI electric water pump
*High rpm circle track power steering pump
*K&N air cleaner
*Barry Grant fuel regulator
*Over the frame headers to 4” bullet mufflers
I can put you in contact with the mechanic that has done the majority of the work on the engine the last time it was freshened.
Dick Cepek Tires and Rims $500
-35x17.5x15 Baja Cepek Tires, 1 new and other 3 have about 1/3
tread left
-Rims are also Cepeks(6 hole)
Call: 952.292.6272
Email: jc77hoernke@yahoo.com
