Modular V10 (6.8l)
Are my heads screwed???
Old 02-19-2011, 07:21 PM
scottf250us's Avatar
scottf250us
scottf250us is offline
I took my truck to have exhaust manifold gaskets put on. mechanic broke and had to drill 14 of the 20 bolts. after 2 weeks i finally got it back. Drove it 5 miles and it leaked a gallon of anitfreeze from around the exhaust manifold bolts. Any input on this?
Old 02-19-2011, 08:28 PM
BigPigDaddy's Avatar
BigPigDaddy
BigPigDaddy is offline
Yep, your heads could be screwed.
Sounds like your mechanic probably drilled into a water jacket. If it took him 2 weeks to do the original job I'd hate to think how long it will take him to replace a head!
He does warranty his work, right?
Who knows, maybe it's a coincidence.
Old 02-19-2011, 09:11 PM
scottf250us
ive used this guy for years and this is the first problem ive ever had with him
Old 02-19-2011, 10:28 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
ZBIGBIG19TH is offline
That sounds bad. Wonder how deep did he had to drill to get in to water jacket.
Old 02-19-2011, 10:40 PM
scottf250us
i know he got at least 1 hole off centered because he cut the hole out of the manifold to make it work. i didnt like that
Old 02-20-2011, 12:20 AM
BigPigDaddy
Mechanic -> <- You
Old 02-20-2011, 08:16 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Smack the guy. I took great pains to make sure when I was drilling out studs that I marked the depth of the drill and did NOT go too far. Off-center? Amateur.
However, having said that, there are bolts in all sorts of Ford motors (FEs come to mind) where the bolt hole goes through into the water jacket.
If he won't replace the head, or better yet, pay for SOMEONE ELSE to replace the head, bring it back, and tell him to use some sort of sealant on the bolt. That should stop the leak.
Then find another mechanic. It might not be him, but some newbie he has working for him. Costing him $'s will (usually) cause him to fire the newbie.
Old 02-20-2011, 08:58 AM
scottf250us
well.. both sides are leaking and i really dont want it "patched up" i want it fixed right. its a 99 f250 that only has 60,000 actual miles on it.
Old 02-20-2011, 09:18 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Wow, both sides... Bring it back and let him know whoever did the drilling broke through into the water jacket, and you want new heads.
Old 02-20-2011, 09:52 AM
Sand_Man's Avatar
Sand_Man
Sand_Man is offline
Not to start an arguement, but do FE exhaust bolts really go through water jackets? I know lots of head bolts go into water jackets in the block (which are easily sealed with sealant), but I've never seen an exhaust manifold bolt go into one in the head. But then again I've never worked on an FE Ford.
Old 02-20-2011, 10:35 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I wasn't talking about exhaust bolts.
Timing cover bolts, water pump bolts, do
Old 02-20-2011, 11:55 AM
BigPigDaddy
All the more reason to be .
Old 02-20-2011, 01:23 PM
ZBIGBIG19TH
Make sure 2003 heads.
Old 02-20-2011, 02:14 PM
scottf250us
i'd love some 03 heads and now would be the time to do it but i dont have the extra cash for the PI intake..ect.. to go with.
Old 02-20-2011, 07:55 PM
Sport45's Avatar
Sport45
Sport45 is online now
Definately take it back. You should be due a set of new or remanufactured heads.
Quick Reply: Are my heads screwed???
