37" tires on a 05 f150
Ok, so I wanted to know what you guys think about if I could fit 37" tires on my truck, 37 x 13.5 in toyo m/t to be spaecific. I added a leaf if the rear and put on new front coils, all in all, it lifted the truck about 1-1.5" in the back and 2.5-3" in the front, it sits higher than if I put a leveling kit, so I wanted to know if you think I can get away with it with some slight rubbing, or if its impossible, I believe it clears the wells no problem, but I am a little concerned with the turning. Anyone have experience with this?
37 will fit but only on stock wheels and 12.50 wide, look at this guys (diesel11b). he has less lift than you
https://www.ford-trucks.com/forums/8...trucks-49.html
