Where to find 5W-40?????
So I've been running my 03 6.0L on 15W-40. In the colder months I plug in, and this winter I've started to light the glow plugs for a bit longer.
I can't say I've ever had an issue. Only once, when it got to -21F overnight did it take two cranks to start.
I'm due an oil change and I figured I'd try 5W-40 to see how it works out given that we still have a few cold months left.
This morning I just drove around to 2 Walmarts, 1 Tractor Supply, 1 Advanced AutoParts and 1 AutoZone. The only 5W-40 any of them had was Shell Rotella T6. Walmart was $19.99 per gallon, the rest were $24.99 per gallon.
The Shell Triple T 15W-40 I've been using is $57 for 5 gallons at Walmart and Tractor Supply ... that's $11.40 per gallon.
Given that I do about 6-7 oil changes a year on the Ford & about 4 on the Dodge ... are there any alternative sources for 5W that aren't as pricey?
Thanks.
I should add that Advanced did have Mobil 1 in 5W-40, but that was only in quart jugs for $7.99 ... that would be $32 per gallon ... WTF!!!!
Thanks.
on
Thanks.
Thanks.
Try to see if any of those places will let you by it by the case. They might be willing to cut you some slack then.
Thanks.
Thanks.
I buy Delo Synthetic 5w40 at Costco Business if they have one in your area, I think its like $15 or $16 per gallon. I usually buy like 20 gallons because I have to drive so far to get it, there is only one Costco Business in Arizona, and its in Phoenix. They have a different selection than regular Costcos, like restaurant and small business stuff, but you can use your regular Costco card there.
Do you have a business number, with all those vehicles, get a commercial fuel card with chevron if they have some bulk plants and you can buy your dell synthetic when you fuel up? I would probably fuel all vehicles same way, it's a few cents cheaper per gallon, but with that many motors would be worthwhile. I usually wait for sales and by 3 cases which each have 4 gallons of oil.
If your gonna run the fully syn rotella 5w40w thats about as cheap as your gonna find it at wal mart. I've owned 6 different Ford diesels and all I have ever used is rotella. I keep a pretty close eye on the prices and $20.00 a gallon isnt to bad. Only way to get it cheaper is catch a sale or go with the conventional but I only ran that in my 7.3's . Its better to run the full syn in the 6.0 . Some of the guys on other forums are running valvoline prem blue full syn 5w40w. They left rotella to go with this. They were not happy with the oil analysis on the rotella. Any thoughts ?
99ExpyProblems
10-07-2013 07:40 PM
99ExpyProblems
10-05-2013 01:50 PM
