Need Help
Old Jan 23, 2011 | 03:41 PM
Jr.460's Avatar
Jr.460
Need Help
Ok I bought a 94 f250 4x4 460 it ran great for a couple a months then I went out one morning to go to work and it did'nt start So I bought a new battery and starter then started to run fine.Then again went out tried to start it.and it would not start.When I tried to start it I smelled something burning looked under the hood and and the braded wire was hot so I thought the negative battery wire. So I looked at it and it was very corroded. So I followed the negtive battery wire to the block and found out it had broken.Is there an easy way to get to the bolt on the block to change the wire?Is there any Tips or tricks to get it so I can put the new one on?
Old Jan 23, 2011 | 05:05 PM
fdude64's Avatar
fdude64
sometimes you have to be a contortionist to get to some of the bolts on our trucks. might be able to go through the fender well with an extension
