MAP Sensor voltage ???
Old Jan 22, 2011 | 12:46 PM
pjnadon's Avatar
pjnadon
What Should the voltage in to the map sensor and out to PCM I have been getting a CEL with codes P0069 MAP - Barometric Pressure Correlation and P0200 Injector Circuit I tested the map sensor and I got max 1.40 volts out and desended when I put the vacum pump to it is there any other sensor i should be testing
Old Jan 22, 2011 | 02:10 PM
dchamberlain's Avatar
dchamberlain
Were you checking with the engine off?
The MAP sensor should have 5 volts going to it, and be returning 0-5 volts when reading a pressure of 0-51 PSI. This is based on the table I cut out of the 6.0L Bible and attached below.
Remember that it is an absolute pressure sensor, so at engine off, it should read atmospheric pressure, which should be about 14.7 PSI at sea level.
Old Jan 22, 2011 | 09:49 PM
pjnadon's Avatar
pjnadon
The way I tested it was with the KOEO I put my hand Vacum pump on the line With my volt meter I tested the voltage on the center wire was 1.40 when I pumped up the vacum pump the voltage would drop The supply power wire was also only 1.40 volts
Does the Baro sensor determine what voltage the MAP Sensor Recive
Old Jan 22, 2011 | 10:01 PM
dchamberlain
Disconnect the connector from the sensor and see if you get 5 volts on pin 1. The power should come from the PCM.
I'm still not entirely sure how these sensors work, but the return voltage you're seeing makes sense according to the table, as does the voltage drop if you apply a vacuum. If you apply pressure, you should see a similar voltage increase.
bismic
Mar 9, 2022 09:20 AM
ernesteugene
Oct 28, 2017 12:48 PM
NLPRacing
29
Nov 7, 2015 05:46 PM
fenix1
Electrical Systems/Wiring
Jun 8, 2013 09:31 PM
Kadiance1183
2004 - 2008 F150
Oct 18, 2008 01:01 PM
