48 Mango Updated Pictures
on
1 Post
Hey Sean, I been pretty busy as well. Just remind me about the grill bars when you are ready for them. The visor I believe came off a car, I believe it was a '53 something.....not too sure as I purchased it from a fella on ebay. Had to modify it to fit, making it about 6" narrower and also had to build my own center support bracket.
I think you cold make just about any visor work, you just need to get creative.
on
1 Post
This took a lot of work. The truck is sitting on a full size Chev 1/2 ton chassis that had to be shortened......then I used 2" dropped spindles with 2 1/2" dropped coils. Also note that the front fenders have had a major reworking (widened 4") and the wheel opening has been reworked as well in order to get the flare and so it hugged the tires a little nicer. Basically, if you want the correct stance, you need to start from the ground up and don't be afraid to dry fit everything at least 4 times like I did....
