Performance Chips
Old Jan 14, 2011 | 01:12 AM
JamesHajek's Avatar
JamesHajek
Originally Posted by powerstoked!
I was only looking at the TS chip because I can get the chip for like $200... And then send it to get tuned. Good info to know though about the DP tuner chips.
That's not bad. It will cost around 100-150 to get it burnt by a custom tuner depending on where you go.
Old Jan 14, 2011 | 03:14 AM
powerstoked!'s Avatar
powerstoked!
ok, here's a good question... You know how you have to order your chip by PCM code for automatic transmissions? If I were to buy this second hand TS chip from another stroker, it doesn't matter what the chip was originally for right? Because when it is reburned by the tuner I would send it to, they would burn programs on for that PCM code right? Or is it something physically different with the chips?
Old Jan 14, 2011 | 08:12 AM
jg96powerstroker's Avatar
jg96powerstroker
yeah, they would clear it and burn it to your mods and what not, if it was a man they will burn it for auto, injecters, what not
Old Jan 14, 2011 | 11:05 AM
JamesHajek's Avatar
JamesHajek
Yep, Send it to a tuner and they will burn it for your truck.
Old Jan 14, 2011 | 11:12 AM
Dave Sponaugle's Avatar
Dave Sponaugle
I went with a DP Tuner F8.
Can hold up to 8 tunes with a rotary switch or 16 tunes with a laptop.
I got,
no start
stock
60 HP econo
80 HP mountain econo
100 HP performance
and have room for more tunes
One feature I like about it, 150 extra for a Destiny Tuner lets me download tunes and install them without pulling the chip.
As far as I know, those have to come from DP Tuner though.
They also have a feature that lets you download tunes and try them for 10 key cycles, try before you buy which I also like.
4.10 gears, E4OD, F350 crew cab 4x4
Around here, I average 13 MPG right now, that goes up about 2 MPG in the summer.
One trip through the mountains since it was installed, 16.5 MPG which would have been a lot better except there was this Duramax ....well I did burn a lot of extra fuel but he went to the back of the line.
Last summer I ran to KC almost non stop, 18 MPG with no chip.
I can't wait to try a long trip with the chip on summer fuel.
With the roads and hills we have here, I am always about 4 MPG below what everyone else sees with both my Stroke and IDI turbo.
Old Jan 14, 2011 | 11:14 AM
Robbgt's Avatar
Robbgt
I think most chips get re-burned TDE1 (auto trans) PCM code... least that's what tony did with mine. The NAW6 PCM shifts like CRAP compared to the TDE1. NAW6 TC lockup point is right before the OD shift . Of course, i believe you can have the shift points adjusted to your liking w/ chip tuning
Old Jan 20, 2011 | 06:22 AM
powerstoked!
So I sent an email to wildman like two weeks ago and got nothing back. Can't say I'm happy about it. I am still waiting to hear back from his shop before I buy this chip... can't even say that I know the Guy still has it. Anybody know a better way to contact TW other than through totaldieselperformance.com?
Old Jan 20, 2011 | 06:27 AM
Robbgt's Avatar
Robbgt
Did you try calling them at 817 932 5078?
Old Jan 20, 2011 | 06:30 AM
powerstoked!
No, my dumb@%# decided that going back to school was a good idea, so i've been running around like a chicken with its head cut off
Old Jan 20, 2011 | 11:47 AM
JamesHajek's Avatar
JamesHajek
Call him. If that doesn't work.
Call this number. 817-925-1909. Ask for Randall Lane. I believe he is doing the work for Tony right now as Tony has another job which makes him a very busy man.
Old Jan 20, 2011 | 11:49 AM
powerstoked!
Thanks bud
ARW
36
Oct 4, 2015 11:44 AM
Tugly
166
Aug 6, 2015 12:46 PM
the_auto_tech
Jan 20, 2015 01:26 PM
DIYMechanic
58
Nov 23, 2013 11:28 AM
the_auto_tech
Jul 5, 2013 09:38 AM
