1978 F150 Rear Leaf Springs
Old 01-07-2011, 07:05 PM
Idaho_truck's Avatar
Idaho_truck
Idaho_truck is offline
Hi, I have a 1978 F-150 ranger XLT. I am looking into getting new rear leaf springs because the truck has been heavily used and is starting to wear down the springs. The problem is, it was lifted by a previous owner and I am un sure if stock F150 springs will still fit, or if it needs bigger springs, being lifted.
Mine is the Blue one and it is next to a F250 (same year)
Old 01-07-2011, 07:17 PM
Ryank78shortbed's Avatar
Ryank78shortbed
Ryank78shortbed is offline
Depends how it was lifted body, blocks, shackle flip, or leaf! Need more info!
Old 01-07-2011, 07:43 PM
Idaho_truck
Ok, Now After looking it over, Im thinking it is still stock. There is no sign of it being lifted, I was just assuming that it was because it was as tall as the f250. Did they make the F150 that tall ? I have not seen any around here as tall as mine. But it could be that this one is the 4wd, 400 engine model?
Old 01-07-2011, 08:31 PM
teds74ford's Avatar
teds74ford
teds74ford is offline
First, hello to a fellow Idaho member!
As far as height, the 150s and the later 250s did sit pretty close in height. It might be that your truck just has bigger tires, making it look lifted.
Old 01-07-2011, 09:24 PM
78 PEB's Avatar
78 PEB
78 PEB is offline
X 2 to a fellow Idaho member............where are you at?I' m in Poky
Old 01-08-2011, 08:03 AM
Idaho_truck
ok yeah that would make sense, i did get some 33" bfg mud terrains.
Im in Nampa
1978fordmoneypit
04-11-2014 08:12 AM
FordMaverickFan
19
07-10-2012 01:35 PM
KrautBurner
70
08-12-2011 10:22 AM
theWeezL
Projects
40
04-19-2011 01:07 PM
offroadracer99
10-22-2010 10:22 PM
Quick Reply: 1978 F150 Rear Leaf Springs
