6.2L V8 Discuss the 6.2L V8
Interesting info on Power Ratings for the new 6.2
Old 01-14-2011, 07:50 PM
MDSuperDuty's Avatar
MDSuperDuty
MDSuperDuty is offline
I was looking on the Ford Fleet website and looking at: 2011 Ford Super Duty Pickup: Specifications and came across this
6.2L* 2-Valve V8 FFV (see the asterisk)
I followed this down to the end of the page and read
<SUP>*</SUP>385 hp and 405 lb.-ft. of torque under 10K GVWR. 316 hp and 397 lb.-ft. of torque over 10K GVWR.
So according to this an F350 would get a lower rated 6.2. Maybe a typo.
Here is the link if interested.
https://www.fleet.ford.com/showroom/...specs.asp?EV=0
Old 01-14-2011, 08:19 PM
MDSuperDuty
If this is indeed truly the case, the 6.2 isnt that much better than the old 5.4, numbers wise for the over 10k trucks. I can't believe this would be true.
Old 01-15-2011, 11:10 AM
MDSuperDuty
Does anyone know if there is any truth to this?
Old 01-15-2011, 11:55 AM
radzer0's Avatar
radzer0
radzer0 is offline
Im not 100% on this but i know ford likes to lower the power on there cab trucks. It could be for cab models ordered for utility bed, etc etc.
After all you can just get a diablo tuner or something to that nature and run in a performance tune for a regular truck. I dont see them doing anything other than programing diff.
Old 01-15-2011, 12:38 PM
countryboy69's Avatar
countryboy69
countryboy69 is offline
I believe that they have the same power but use a different (lower rpm rating as opposed to max hp and torque) for over 10,000 lbs.
Old 01-15-2011, 01:00 PM
MDSuperDuty
I've noticed they lower numbers for the cab & chassis but this is under the regular pick up section??
Old 01-15-2011, 01:11 PM
capn kirk's Avatar
capn kirk
capn kirk is offline
its a government thing in the over 10k trucks. Same motor same power but the published numbers are lower
Old 01-15-2011, 01:12 PM
radzer0's Avatar
radzer0
radzer0 is offline
I dont believe the fleet section shows the regular model trucks. Only the work models.
Old 01-15-2011, 01:17 PM
MDSuperDuty
Interesting
Old 01-15-2011, 01:19 PM
MDSuperDuty
Well when you select the truck to spec out it allows for Ranger, 150, 250, 350, 350 chassis, 450 chassis, 550 chassis. But maybe its that. On that link I provided you can click on "Trucks" on the left column and see the available truck options.
Old 01-15-2011, 01:53 PM
radzer0's Avatar
radzer0
radzer0 is offline
On fords regular site even the 450 shows the full hp rating. Its only those fleet work trucks that are cut back.
Old 01-15-2011, 02:08 PM
MDSuperDuty
Hmm. Well maybe that explains it.
Old 01-15-2011, 02:09 PM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,496 Likes on 1,305 Posts
Old 01-15-2011, 02:20 PM
MDSuperDuty
Originally Posted by scraprat
Thanks for the info!!
Old 01-15-2011, 04:34 PM
Tom's Avatar
Tom
Tom is offline
Not quite.
It's the chassis/cab trucks as opposed to pickups. Because even the F350 chassis/cab is rated for a higher GVWR than the F450 pickup trucks. This puts it over 14,000 lbs, which puts it in an emissions category that requires a different emissions certification.
Attaining that requires the de-tuned PSD, but both the v10 and 6.2 are at their full designed horsepower.
On edit: Unfortunately due to government intervention the advertised horsepower ratings are now very misleading to everyone. I wish something was present on the Ford advertising literature that explained this better!
Quick Reply: Interesting info on Power Ratings for the new 6.2
