77' charging system doesn't work!
Old Mar 5, 2003 | 11:15 AM
Turgid77's Avatar
Turgid77
I have a 1977 F-250 and the charging system is not working at all. I have had the alternator and battery tested and both are in good working order. The battery will hold a charge as long as the pickup is not running. I have measured the voltage at the battery and come up with just over 12v while not running and about 14.5v when it is running.
Where should I go from here?
Old Mar 5, 2003 | 11:32 AM
amp17757's Avatar
amp17757
It sounds like your alternator is intermittently failing to charge the battery. My guess is a bad connection somewhere. Have you removed the battery cable terminals lately?? Cleaned & lubed them?? I think if they were the problem, you would have STARTING problems also, but then again, you probably DO have starting problems. I would also check ALL the connections on the alternator, all connections remote from the alternator, and all connections at the starter solenoid. Make sure they're all clean & snugged up, no breaks anywhere. Let us know what happens.
Old Mar 5, 2003 | 07:35 PM
Mike W's Avatar
Mike W
Also check the fan belt to be sure it is tight. I had one that was semi-loose. It would be ok until the lights were on.
Old Mar 6, 2003 | 11:42 AM
amp17757's Avatar
amp17757
Mike W , GOOD POINT! I've had that happen. Sometimes the belts don't squeal, so you don't even know they're slipping.
diesel_dan
Electrical Systems/Wiring
39
Mar 24, 2012 09:31 PM
Foamy
Aug 3, 2008 08:48 PM
77 bird
Jan 31, 2008 10:02 PM
Pocca
Jul 25, 2007 01:31 PM
wparente
Aug 26, 2006 02:06 AM
