1966 - 1977 Early Broncos
transfercase shifter?
Old Mar 5, 2003 | 09:28 AM
spartamouse1's Avatar
spartamouse1
i am getting tired of fighting the j-shifter. anybody seen a twin stick they like?? it is a pain to get back into 2wd high. half the time i think i have it back it is in 4wd high and i have the hubs unlocked and don't even know it.
Old Mar 6, 2003 | 12:12 AM
RCrawler's Avatar
RCrawler
There are several companies offering twin stick shifters. I haven't heard anything bad about any of them. They will require the shift rails to be modified. And if you want true front and rear axle control, the transfer case needs to be disassembled and modified.
If your original shifter is sloppy, you may just need a rebuild. Its amazing how well the J shifter works when they are not completely worn out from lack of lubrication.
Jason
Old Mar 6, 2003 | 08:29 AM
spartamouse1
shifter feel pretty tight, and i soaked it in oil being it had been sitting for the last 12 yrs. i pulled the transfercase out last night. guess i will look inside and see if anything inside is causing the problem. i did not know you had to modify the shift rails. i hate to do anything to it that can't be undone.
thanks
Old Mar 10, 2003 | 02:12 PM
spartamouse1
it was the shifter after all. had a nasty burr in it. slicker than snott now.
Old Mar 10, 2003 | 11:19 PM
RCrawler's Avatar
RCrawler
Excellent.
Jason
