really bad mileage??
Old 12-23-2010, 12:44 AM
blueovalbigblock's Avatar
blueovalbigblock
blueovalbigblock is offline
hey guys. im just wondering about my fuel mileage. right now around town im getting about 10-11 mpg and on the highway 13 maybe 14 on a good day. is this normal for a truck with the mods i have? (stage 2's, turbo housing, chip, big tires etc) even on my low tunes it stays about the same. i know i dont have any fuel leaks. changed all the lines and filter and air filter and oil. i figured my mileage would go down with the bigger ingectors and big tires but i didnt think it would be that bad. the only thing i can think to check is the ebps tube to see if its plugged. my truck runs amazing it just sucks fuel like my girlfriend does money! lol any ideas greatly appreciated!
Old 12-23-2010, 01:13 AM
Muktown's Avatar
Muktown
Muktown is offline
Honestly with a set of 37s unless you changed the gearing id say your about right
If you didn't recal the speedo you will be travelling more miles than your odometer says which would mean you're actually getting a little better milage than you think
Old 12-23-2010, 01:23 AM
blueovalbigblock
alright thanks thats what i thought lol and i forgot that the size change affects the odo too not just the speedo thanks for reminding me. im looking for a set of 315 70 17's now so hopefully that will help till i can afford the fuel to look cool haha
Old 12-23-2010, 01:53 AM
chicagodragon's Avatar
chicagodragon
chicagodragon is offline
tj beggs posted this...from here:
http://pages.prodigy.net/stevebaz/_i...az/index3.html
Recalibrate Your Speedometer After Changing Tire Size
There is no tire size/code chart because tire size vs. actual tire dimensions are different between manufacturers. Even between the same tire size and same maker there will be a difference in actual size between the different tread designs.
The Ford calibration equation is:
20186 / tire height in inches = some number, then: some number /.6666 = program code
Example:
Start with 20186, divide by actual tire size in inches. Divide again by .6666
You want to use a rolling measurement to get your actual tire height (If you try to measure the tire in the driveway, use conversion charts, or anything else you will end up with an inaccurate reading again). Use your rear tire since the sensor is located there. Mark the ground and your tire and roll forward 3 times marking the ground each time. (I ran over a spot of oil at a local gas station and measured between my tread mark prints), then divide that number by three to get the average length of one revolution (this will protect yourself against a bad reading using just one revolution). You can then divide the length of one revolution by 3.14 to get actual tire height. Be careful in your measurements, a small amount will change the code. EX: 31.69" tire height is code 956, and 31.21" tire height is code 970.
Now, to program it into your truck:
Warning: You can only change the calibration 6 times without replacing the module.
To set the calibration, ground the single wire connector under the glove box it says PSOM (Programable Speedometer Opdometer Module). ”Yes there is only one and it has a spade type plug on the end". I used a wire with clips on both ends to ground the plug to a screw under the dash or try a test light and use the clip end to the PSOM and the other jam in a dooe hinge. Now look at your speedometer on the face of your dash while sitting in the drivers seat and there should be a "reset" button and a "select" button. While holding the reset button in on the trip meter, turn the ignition to 'on' while the wire is still grounded. Let go of the reset button. The speedometer display will sweep once and will show a code of some kind then push in again the "reset" button and the existing code will be displayed with RECAL?, mine said 976 RECAL? Now you enter your new code you came up with by dividing the rolling measurement by PI or 3.14 by pushing the "select" button until it gets to the new calibration code number. You may have to push “select” a whole bunch of times until you get to your code. If you turn off the key at this point the original code will not be changed or any of the 6 lives will not be used. To store your new code press “Reset”. Turn off the key. Unplug the ground wire. To check the new calibration, use the mile markers on the interstate. Run an indicated 60 mph and it should take exactly 60 seconds to go 1 mile.
